Date/Time: Thu, 18 Apr 2024 23:03:22 +0000
Horizontal Lines
View Count: 418
[2022-05-17 10:15:43] |
User476926 - Posts: 56 |
Please can we have a Horizontal Lines study that works on "units of price/price increments" rather than "absolute price"? I use HL study to highlight key price levels, however even with 40 levels, on the ES/CL I am regularly having to manually re-enter all 40 levels as price moves. E.g. ES intraday chart highlighting 4000, 4020, 4050, 4080, 4100 E.g. ES daily chart highlighting 4000, 4200, 4500, 4800 So rather the entering 40 individual prices, would be much easier if we could use use price increments on RH scale to highlight: 00, 20, 50, 80, 100 00, 200, 500, 800, 1000 00, 0.20, 0.50, 0.80, 1.00 etc. |
[2022-05-17 13:03:18] |
Matador Trader - Posts: 24 |
+1
[2022-05-17 15:33:06] |
John - SC Support - Posts: 30953 |
You might want to use the Horizontal Grid rather than the Horizontal Lines study. You can set an increment at which you want the grid to show up. Refer to the information here: Chart Menu: Horizontal Grid (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-18 10:28:44] |
Unfortunately I don't think that works. Firstly because the price increments will be variable not fixed (20, 30, 50) and secondly because if I highlight say "20" and "50" lines, I still need to see the 21, 22, 23 etc levels (as non highlighted) for intraday chart.
[2022-05-18 17:18:41] |
We will see if we can put together a study quickly to do what you are looking for.
[2022-05-23 09:09:00] |
This will be out in the next release.
[2022-06-21 11:16:42] |
Thanks for quick response and solution is great. Much more flexible / easier to use (using v2400).
