Date/Time: Thu, 28 Mar 2024 15:41:08 +0000
CONNECTING TO AMP
View Count: 375
[2022-05-16 16:14:57] |
User99624 - Posts: 1 |
Have login credentials from Amp to trade with Sierra Chart. I selected Level 3 data, and CGQ for order routing. CANNOT CONNECT.
[2022-05-16 18:05:49] |
John - SC Support - Posts: 30426 |
The account from which you have posted to this Support Board is Expired. If you have another account that you use, then we need for you to post from that account. Otherwise, the first thing you need to do is to add funds and activate a Service Package in order to use Sierra Chart. Refer to the information at the following link for how to activate your Sierra Chart account: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 10:07:32] |
We have temporarily activated your Sierra Chart account so you can connect. Instructions to connect: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
