Date/Time: Thu, 28 Mar 2024 17:16:48 +0000
opened chart number limit
View Count: 364
[2022-05-15 14:28:05] |
User78439 - Posts: 21 |
How many charts, which include indicators an strategies and running in real-time, can be opened at the same time ? In sierra chart, there is MACD divergence build-in alert ?
[2022-05-16 13:15:11] |
There are no limits. But the operating system will have limitations but we do not know what those limits are. They can be overcome with new instances: Using DTC Server for Data and Trading in Another Sierra Chart Instance In sierra chart, there is MACD divergence build-in alert ? Have a look at this Divergence study:Divergence Detector Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-20 19:04:39] |
As each chart has the same condition of divergence alert, I need to open a chart for every symbol ? Or Sierra chart has a scanner which allows me to set conditions and symbols without all charts opened ?
[2022-05-20 19:54:57] |
John - SC Support - Posts: 30428 |
Refer to the following: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-26 20:01:53] |
I just want a real time US (NASDAQ) stock for such scanner with conditions that I define. What kind of package I should choose ? Thanks
[2022-05-26 20:03:57] |
You would need Service Package 10 for this.
