Date/Time: Fri, 29 Mar 2024 07:00:43 +0000
timing off
View Count: 284
[2022-05-13 16:33:08] |
User229460 - Posts: 24 |
it is 8 pm thu and the chart says fri
[2022-05-13 17:15:58] |
John - SC Support - Posts: 30444 |
Check your Time Zone settings: Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-13 18:19:23] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
