Date/Time: Thu, 28 Mar 2024 23:18:48 +0000
[User Discussion] [Locked] - Recenter DOM To Current Price
View Count: 302
[2022-05-12 20:16:07] |
User143681 - Posts: 45 |
Hello, when double clicking the left mouse button on the dom to center price isn't working, the dom jumps to another area and need to scroll n scroll to locate current price. The dom trading symbol is micro mini s&p and due to volatility the range of the dom is normally stretched out. Scale settings are interactive scale move and scale constant range. The chart with the dom is set using market profile vs. candles. If there is a known issue with this feature, is there another method to quickly center the dom to current price? Thank you.
Date Time Of Last Edit: 2022-05-12 20:27:24
[2022-05-12 21:09:20] |
John - SC Support - Posts: 30444 |
In Constant Range mode, double left-clicking (reset scales) should always center to the last price of the last bar that is displayed in the chart. This may not be the most recent price for the symbol. In the case of a Trading DOM, since there are no bars, it will always be the last price. Is this not the behavior you are seeing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
