Date/Time: Fri, 19 Apr 2024 08:09:29 +0000
Squaring a chart
View Count: 303
[2022-05-12 17:46:17] |
User540504 - Posts: 15 |
Hello Engineers, I'm trying to square my chart so that one unit of time equals one unit of price (tick), so that once set it will stay locked. I have tried to use the X & Y constant relationship but it doesn't appear to make much of a difference, and when I open up scale settings again after checking to see if my parameters work I get totally different values upon opening up scale settings again. Any insight? |
[2022-05-13 17:21:31] |
Sierra_Chart Engineering - Posts: 14006 |
We do not see any problem with the functionality. The Values Range will change in the X and Y Constant Relationship Settings with changes to the scale, but the proper ratio is always maintained internally as originally set. Documentation: Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
