Date/Time: Thu, 28 Mar 2024 13:18:36 +0000
Market Depth - Replay Historical Intraday
View Count: 484
[2022-05-12 00:27:47] |
User263711 - Posts: 11 |
I subscribed to Level 11 Advanced. I like to replay my intraday chart with multi-level Market Depth on DOM Is this possible to L11 service package or do I have have to upgrade to L12? Under Symbol settings, i have enabled market depth historical, but when I replay i only see top-of-book |
[2022-05-12 14:02:46] |
John - SC Support - Posts: 30401 |
You do NOT need to be on Package 12 for what you are wanting to do. Refer to the information at the following link for how to replay Market Depth data: Replaying Charts: Replaying of Market Depth Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-12 17:21:36] |
I followed the steps on that page, enabled Market depth for ES , but my DOM doesn't have market depth beyond the first level. Attached are my settings. What am I missing out? |
DOM - dont have market depth.png / V - Attached On 2022-05-12 17:20:35 UTC - Size: 186.53 KB - 98 views symbol setting.png / V - Attached On 2022-05-12 17:20:40 UTC - Size: 65.94 KB - 106 views chart - no market depth.png / V - Attached On 2022-05-12 17:21:02 UTC - Size: 191.7 KB - 108 views |
[2022-05-12 17:49:13] |
Sorry - we did not check your exchanges as your original post mentioned replay, so we assumed it was a replay only issue. The problem is that you do not have any exchanges activated that include Market Depth. You can change your active exchanges at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-12 19:34:04] |
I have activated my CME Full Market Depth and made the payment.
