Date/Time: Thu, 28 Mar 2024 09:44:45 +0000
set up auto
View Count: 375
[2022-05-11 12:24:26] |
User914407 - Posts: 31 |
Bonjour, SIERRA est-il capable de mettre automatiquement les POC, VPOC, VA, VVA etc ... de la veille ? Merci |
[2022-05-11 14:28:29] |
Yes this is all fully supported. Refer to: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines This Input may or may not be relevant to what you want to do: Volume By Price Study: Number Of Periods Back To Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-11 14:35:04] |
Si je comprend bien, il s'agit des VA, POc etc ... de la journée en cours. Ce que je voudrais , c'est sur celle de la veille ... Merci |
[2022-05-11 17:04:00] |
John - SC Support - Posts: 30399 |
From Google Translate: If I understand correctly, these are the VA, POc etc ... of the current day.
What I would like is on the one from the day before... This Input that was referenced above, lets you reference a prior day: Volume By Price Study: Number Of Periods Back To Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-12 13:16:42] |
J'ai suivi : " Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines " mais rien ne s'affiche sur le Market Profile ... |
[2022-05-12 15:21:35] |
From Google Translate: I followed :
" Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines " but nothing is displayed on the Market Profile... If you are wanting to see the POC and Value Area for a Market Profile (TPO), then refer to these instructions: Time Price Opportunity (TPO) Profile Charts: Highlighting the Value Area and Point of Control The link referenced above is for Volume by Price studies. If you are trying to do this on a Volume by Price, then following those instructions should work. We would need to see a screenshot of your chart after you have set this up to see what it looks like. You can get us a screenshot by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
