Date/Time: Thu, 18 Apr 2024 19:52:44 +0000
Copy Chart drawings
View Count: 1888
[2013-04-26 12:55:52] |
sierrartb - Posts: 11 |
Hello, how could I copy chart drawings into the chart, which is used as overlay study? Thank you. |
[2013-04-26 16:26:47] |
It is not completely clear what you are asking about. However, if you want to copy chart drawings from one chart to another, refer to this page: http://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-15 08:00:58] |
Hello, please see the printscreen. I dont know how to copy chart drawings into the chart NQ-201306. Thank you. |
sierra.jpg / V - Attached On 2013-05-15 08:00:01 UTC - Size: 191.05 KB - 620 views |
[2013-05-15 20:49:46] |
Please describe what you mean by "chart drawings". Please refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-16 08:52:38] |
For exapmple "Extending Rectangle" or "Line".
[2013-05-16 17:09:52] |
You can definitely copy Extending Rectangles or Lines chart drawings from one chart to another. This is explained here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart Are the charts within the same Chartbook? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-17 07:50:09] |
Please see the screenshot above. I can copy chart drawings into the chart YM-201306, but not into the chart NQ-201306, because NQ-201306 is used as a study (overlay bar) for YM-201306. If I am wrong, please send me some screenshot how to do it. Thank you. |
[2013-05-17 07:54:45] |
OK we understand what you are trying to do now. This is not going to work as expected. Drawings will only copy into the same Chart Region they originate from.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-17 07:55:20
