Date/Time: Fri, 29 Mar 2024 14:33:47 +0000
OpenChartOrGetChartReference() DaysToLoad incorrect
View Count: 627
[2022-04-13 14:05:51] |
User660727 - Posts: 50 |
Sierra Chart version 2383 The DaysToLoad value passed to OpenChartOrGetChartReference() is not being correctly set. In the example below, setting the value to 15 results in an actual value of 45. Set the attached screenshot for the actual result of running this example. #include <sierrachart.h> SCDLLName("SCTest"); int dcNum {}; void CrupdateDataChart(SCStudyGraphRef sc) { s_ACSOpenChartParameters cfg; cfg.PriorChartNumber = dcNum; cfg.Symbol = sc.GetRealTimeSymbol(); cfg.ChartDataType = INTRADAY_DATA; cfg.IntradayBarPeriodType = IBPT_DAYS_MINS_SECS; cfg.IntradayBarPeriodLength = 1; cfg.DaysToLoad = 15; cfg.SessionStartTime.SetTime(sc.StartTime1); cfg.SessionEndTime.SetTime(sc.EndTime1); cfg.EveningSessionStartTime.SetTime(sc.StartTime2); cfg.EveningSessionEndTime.SetTime(sc.EndTime2); cfg.LoadWeekendData = 1; cfg.UseEveningSession = 1; cfg.HideNewChart = 1; cfg.UpdatePriorChartNumberParametersToMatch = 1; cfg.ContinuousFuturesContractOption = sc.ContinuousFuturesContractOption!=CFCO_NONE ?sc.ContinuousFuturesContractOption :CFCO_DATE_RULE_ROLLOVER; dcNum = sc.OpenChartOrGetChartReference(cfg); } SCSFExport scsf_SCTest(SCStudyGraphRef sc) { if (sc.SetDefaults) { sc.AutoLoop = 0; return; } if (sc.LastCallToFunction) { return; } if( sc.UpdateStartIndex==0 && sc.IsFullRecalculation ) CrupdateDataChart(sc); } |
daystoload.png / V - Attached On 2022-04-13 14:05:13 UTC - Size: 82.73 KB - 122 views |
[2022-05-01 00:22:51] |
Bump. This is a clear bug including sample code to reproduce. Please fix.
[2022-05-06 02:28:48] |
Sierra_Chart Engineering - Posts: 13625 |
We apologize for the delay. We are checking on this.
[2022-05-06 15:18:01] |
As we suspected, the problem is not reproducible even when we have set a default number of Intraday Days to Load. We have added this to the documentation: When getting a reference to an existing chart, if the existing chart has a higher Days to Load setting, then that chart will be returned and that Days to Load setting for the existing chart will remain.
[2022-05-06 15:59:56] |
My study requires data at second granularity regardless of the granularity of the user's chart. In order to get second level data, my study creates a hidden chart that attempts to match the user's chart settings, including number of days to load. When the user changes their "days to load" to a smaller value (say from 45 to 15), I need to have the second data match. Do I just need to avoid trying to reuse the existing chart and recreate the chart each time to accomplish this?
[2022-05-08 17:15:51] |
We will implement a solution for this by adding a new variable to always use the exact number of days specified.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-08 17:15:57
[2022-05-09 14:15:24] |
This has not yet been tested but we have added this variable which you can set to 1: s_ACSOpenChartParameters::UseExactMatchForDaysToLoad This is in the latest prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-09 14:28:27] |
How will I know when this moves to production? Also, a similar problem exists with timezones. The attached chart time zone does not match the study time zone. This makes using the data difficult as there is no way to even query the time zone. See How to set hidden chart time zone to match study chart |
[2022-05-09 14:32:45] |
It already has been released. It is considered production at this time. There is a new function in ACSIL to get the time zone and you can specify the time zone with s_ACSOpenChartParameters. This has all been developed and released. Check the latest SierraChart.h file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-09 14:48:13] |
What is the name of the new time zone function? What is the name and possible values for the new s_ACSOpenChartParameters time zone parameter?
[2022-05-09 16:50:33] |
The function is: SCString sc.GetChartTimeZone(const int ChartNumber); When opening a chart use this string member to set the time zone string: s_ACSOpenChartParameters::ChartTimeZone Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-13 15:47:17] |
Is there a reason that documentation is not updated with these features? Will there be long term support for this new functionality?
