Date/Time: Fri, 19 Apr 2024 19:23:32 +0000
ETHUSD_PERP_BINANCE's volume is displayed as multiplied by 10000x by default
View Count: 526
[2022-04-09 19:12:03] |
User776925 - Posts: 7 |
To further explain, the volume's on ETHUSD_PERP_BINANCE are about 10000x larger than they should be. Values look outrageous when the volume multiplier is set to 1. The multiplier has to be set by the user to be 0.0001 in order to have the real volumes displayed correctly. I was able to confirm this by viewing the order book and the time and sales from the Binance website and the values are being multiplied on Sierra Chart (Ex. Binance values are $30 while Sierra Chart footprint or time and sales will show 300,000 (300K with large number prefix)). While it is fine to set the volume multiplier to 0.0001 manually, I am unable to set a volume multiplier to the time and sales as well as the trading DOM (price ladder). Can this be fixed through a new update and can a user set this fix for themselves in the meantime?
[2022-04-12 13:08:55] |
Sierra_Chart Engineering - Posts: 14014 |
Yes this is true. Refer to: Cryptocurrency / Bitcoin Data and Trading Services: Notes We will have to see about the other volume multipliers you are asking about. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-12 13:09:34
[2022-04-16 00:06:42] |
How would I be able to see Binance volumes normally on the Time and Sales window? Since they are all multiplied values.
[2022-05-18 19:29:55] |
Newer versions allow you to do this because there is a new Time and Sales volume multiplier setting in the Chart >> Chart Settings >> Chart Data window that works specifically with the Time and Sales window. So you could use a setting of .0001 for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-18 19:30:13
