Date/Time: Fri, 19 Apr 2024 18:34:15 +0000
my data is delayed i purchased data from sierra chart but it is delayed compared
View Count: 409
[2022-04-08 20:02:45] |
colt45 - Posts: 2 |
according to ninjatrader 8 my data is delayed I purchased data from Sierra chart but it says delayed at top of screen and numbers differ from ninjatrader platform to sierra chart can you help fix this issue???
[2022-04-08 22:14:07] |
John - SC Support - Posts: 30973 |
You have not completed the setup for the Denali Exchange Data Feed. You need to go through the instructions at the following link for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Or the following link if you are wanting data from EUREX, CFE, or NASDAQ TotalView: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* If you are wanting real-time data from the CME Group, then you need to be able to connect to your trading account in order to qualify for the non-professional exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
