Date/Time: Thu, 25 Apr 2024 12:50:27 +0000
Copying a single indicator to a new chart
View Count: 673
[2022-03-25 23:42:00] |
Matador Trader - Posts: 24 |
I have multiple chartbooks that I have from different sources. I want to create my own chartbook with some of the indicators from these chartbooks. So my question is how do I copy a single indicator with the settings to a new chart? Thanks in advance. |
[2022-03-26 21:09:26] |
caligola - Posts: 116 |
save the single study as a single study collection remember to select Prompt to Remove Existing Studies Study Collections: Create a Study Collection then switch to your destination chartbook and open the chart where you want to apply that previously saved study Study Collections: Applying a Study Collection to a Chart Date Time Of Last Edit: 2022-03-26 21:13:15
[2022-03-28 17:56:39] |
Thanks - was so simple.
[2022-05-11 18:10:22] |
Nkrastins - Posts: 34 |
Hello, ok if I want to copy one indicator to a new chartbook with existing indicators on it? Those indicators will disappear, how do I keep them? Thanks |
[2022-05-11 20:38:55] |
John - SC Support - Posts: 31098 |
As noted above, you need to select the option when you are saving the Study Collection for Prompt to Remove Existing Studies. When this is enabled, then when you go to add the Study Collection the system will ask if you want to remove the existing studies or not. Refer to the information here: Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
