Date/Time: Thu, 25 Apr 2024 14:58:16 +0000
Reset Current Traded total volume and Current Bid x Ask separately on DOM
View Count: 912
[2022-03-17 17:16:23] |
stephenvosloo - Posts: 28 |
Hello, SC engineering. Is there a way to allow for a separate action to reset Current total traded volume and Current Bid x Ask on the DOM Chart. I realize that the data is technically the same but as I'm using it on my DOM, it would be great to have the ability to see volume build from a certain point compared to what I'm seeing in Current trades Bid x Ask. At the moment both reset at the same time. Thank you! |
[2022-03-17 17:42:05] |
John - SC Support - Posts: 31101 |
There is not a way to do this. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-17 19:37:26] |
brilliant, thank you John!
[2023-01-26 01:39:54] |
Rylan Llamado - Posts: 2 |
Hello, has this feature been added yet?
[2023-01-26 15:34:24] |
No, this has not been implemented yet.
[2023-03-13 03:26:36] |
jmftattoo - Posts: 76 |
Editing my original question as I see this feature has been added. I have created a hot key for the functionality but when clearing the current traded bid/ask volume it clears ALL my Doms. I have un-linked all Doms, and symbols but they still all clear when hitting the keystroke. Is there a way to ONLY clear the dom currently selected EVEN if it’s for the same symbol. I have filtered Doms for same Es symbol and DONT want to clear those. I only want to the clear the current execution dom I am actively trading. That way I can compare contrast current traded volume vs entry current traded volume. Date Time Of Last Edit: 2023-03-13 05:03:01
[2023-03-13 17:09:10] |
