Date/Time: Sat, 12 Sep 2026 07:11:44 +0000
Unable to connect TT FIX through sierra on a cloud server
View Count: 1340
[2014-04-11 14:37:15]
xfighter - Posts: 36
Hi Folks,
Today I try to connect TT FIX by using a cloud server and get following error messages:
TT FIX: Connecting. | 2014-04-11 10:01:26
Starting the Price Feed session. Connecting to 66.150.104.21 port 10502... | 2014-04-11 10:01:26
The network socket is connected. | 2014-04-11 10:01:26
TT FIX Data: Sending the Logon message. | 2014-04-11 10:01:26
TT FIX Data: Received a Logout message. Text = Unable to login to adapter NINJA-PRICE: FA-USER 131 is not authorized to use FIX Adapter.. Please contact your System Administrator. | 2014-04-11 10:01:26
TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2014-04-11 10:01:26
Socket has been shutdown and closed. | 2014-04-11 10:01:26
TT FIX Data: Logged out and disconnected. | 2014-04-11 10:01:26
Disconnected from TT FIX Price Feed session. | 2014-04-11 10:01:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-11 10:01:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-11 10:01:26
On my local computer, this never happened. Did I do anything wrong?
Thank you!
[2014-04-11 15:06:56]
One thing I need to mention:
On my local computer, I am running windows 7.
On the cloud server, I am running windows server 2008 r2.
Can this be the problem?
[2014-04-11 16:29:52]
This clearly looks like a problem with the Price Feed settings in File >> Data/Trade Service Settings. Check them and contact your broker for further help.
[2014-04-11 20:26:36]
Futures Operator - Posts: 239
Are you trying to login to both connections simultaneously from the same account? TT FIX does not support that, you would need two accounts.
