Date/Time: Sat, 12 Sep 2026 08:25:51 +0000
right side space/margin
View Count: 1899
| [2014-04-09 10:16:39] |
| User021827 - Posts: 174 |
I cant find a setting to have a space between the chart candles and the right side of the window where the price is. I would like to have volume profile on the right and a space between the profile and the candles. Where can I find this setting for adjusting the space on the right side ? thanks shane |
| [2014-04-09 10:22:41] |
Refer to: https://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#RightAligning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
