Date/Time: Thu, 28 Mar 2024 15:33:15 +0000
Exchange Fees
View Count: 891
[2022-01-14 18:16:33] |
kinobi - Posts: 15 |
I have subscribed to Advanced Package with Denali. I trade ES/NQ and stocks and use IB. What is the least expensive data exchange package that I should get?
[2022-01-14 20:25:05] |
John - SC Support - Posts: 30423 |
It depends on what you need. If you just need data for ES and NQ and do not need data from any other CME Group exchange, then the cheapest option is the following: - CME non-professional top-of-book: $1.25/month If you need Market Depth data for these symbols as well, then you would want to go with the following: - CME with Market Depth for nonprofessional Trading accounts If you do need data from other exchanges, then you would need to determine which ones and whether you need market depth data or not. In the end, the trick is that if you need data from 3 of the exchanges, then you should just get the entire bundle, as the cost is the same for 3 individually versus the bundle of 4. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-15 01:45:29] |
I guess I am doing something wrong. I have subscribed to Denali data and $11 for exchange data package. It also seems like I need SC connection $25 per mo to have access to stocks ? Do I read it correctly? |
[2022-01-15 03:38:07] |
Yes, if you want to use our Sierra Chart Exchange Data Feed but wait. We have a new NASDAQ stock data feed with market depth we will be providing at the beginning of February.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-15 03:38:13
[2022-01-16 19:14:58] |
For the 2 options for ES you mentioned do I still need Denali data feed?- CME non-professional top-of-book: $1.25/month If you need Market Depth data for these symbols as well, then you would want to go with the following: - CME with Market Depth for nonprofessional Trading accounts Not sure I understand your reply in reference to stocks..I need access to all stocks.. do I need to pay $25 connection fee? what will take place on Feb 1st? |
[2022-01-17 16:08:44] |
Yes. In order to get the data for the CME Group, you need to use the Denali Exchange Data Feed, which requires that you are on package 10+, and you have the exchanges you want activated. Not sure I understand your reply in reference to stocks..I need access to all stocks.. do I need to pay $25 connection fee? what will take place on Feb 1st?
The stock data is currently on a separate data feed that we have called the Sierra Chart Exchange Data Feed. For this particular data feed, you need to pay $25.00 for the data feed itself and then $10.50 for the exchange fee. In a few week we expect to have our new NASDAQ data feed available. This will replace our existing U.S. Equities exchange and will be part of the Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
