Date/Time: Thu, 25 Apr 2024 11:40:52 +0000
Datafeed AMP Konto
View Count: 559
[2022-01-14 15:11:53] |
User936134 - Posts: 1 |
Hallo, ich würde gerne den Datefeed aktivieren, jedoch fehlt mir die Verifizierung meines AMP Kontos. Wie lange brauchen sie noch dafür? Viele Grüße A. Österle |
[2022-01-14 19:07:58] |
John - SC Support - Posts: 31098 |
From Google Translate: Hi there,
I would like to activate the datefeed, but I don't have the verification of my AMP account. How much longer will it take them? What exactly are you looking for in terms of the "Verification of my AMP account"? If you have an AMP account setup, then you need to connect to that AMP account. They should have set you up with order routing using either CQG or Rithmic. Therefore, you would need to connect your Sierra Chart to whichever service they have set you up with. If you are setup with CQG, then follow these instructions: CQG Trading Platform Service: Setup Instructions If you are setup with Rithmic, then follow these instructions: Rithmic Trading Platform Service: Setup Instructions If you are not planning on staying connected to your AMP account, then refer to the following for how to connect once a month to verify your non-professional status for the CME Group: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees And finally, once you do get setup, you will need to finish the setup for the Denali Exchange Data Feed. Follow the remaining instructions starting here: Denali Exchange Data Feed: Activate the Exchanges (Denali Exchange Data Feed Setup Instructions) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
