Date/Time: Tue, 23 Apr 2024 18:29:46 +0000
Volume Point of Control for Bars
View Count: 511
[2022-01-13 13:15:46] |
User185037 - Posts: 21 |
В какой минимальный пакет входит исследование Volume Point of Control for Bars?
[2022-01-13 13:47:22] |
frozentundra - Posts: 84 |
по моему этот Sierra Chart with Advanced Features (Service Package 5)
сылка - Description of Service Packages and Pricing: Packages |
[2022-01-13 15:48:05] |
John - SC Support - Posts: 31046 |
From Google Translate: What is the minimum package for the Volume Point of Control for Bars study?
For this specific study - Volume Point of Control for Bars you can be on any package (including Package 3). It does not require any special package. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-13 18:27:30] |
Спасибо! Скажите, будет ли работать реал тайм данные с пакетом №3 + CME with Market Depth for nonprofessional Trading accounts ??? 2022-01-31 Automatically Renews. 11 USD / month. https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed |
[2022-01-13 19:37:19] |
From Google Translate: Thanks! Tell me, will real-time data work with package No. 3 + CME with Market Depth for nonprofessional Trading accounts ???
2022-01-31 Automatically Renews. 11USD/month. In order to get the Denali data, you need to be on Package 10, 11, or 12. Therefore, unless you need something from the Advanced Package (TPO, Numbers Bars, etc.) you could change to Package 10. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-14 04:02:51] |
Я не понимаю для чего мне Denali Data. В таком случае для чего существуют пакеты без Denali data? Объясните мне от обратного, что случиться ( или не случиться) если я включу пакет №3 + CME with Market Depth for nonprofessional Trading accounts. а) я не смогу торговать? б) будет задержка котировок? в) не будет данных вообще? г) и т.д. Могу ли я сам проверить, что произойдет: скажем перейти на 3 пакет и включить программу, если нет результата перейти на пакет 10? Прошу перечислите все моменты, потому что я искренне не понимаю для чего Denali, что дают эти данные и почему есть пакеты без Denali. Благодарю! |
[2022-01-14 15:45:34] |
From Google Translate: I don't understand why I need Denali Data. In this case, why are there packages without Denali data?
Explain to me in reverse what will happen (or not happen) if I enable package #3 + CME with Market Depth for nonprofessional Trading accounts. a) I will not be able to trade? b) will there be a delay in quotes? c) there will be no data at all? d) etc. Can I check for myself what happens: say, go to package 3 and turn on the program, if there is no result, go to package 10? Please list all the points, because I sincerely do not understand what Denali is for, what these data give and why there are packages without Denali. Thanks to! Denali is a Data Feed. That is all. It is your choice if you want to get the data from us through our Denali Exchange Data Feed, or if you want to get your data from your trading service (it looks like you are connected to CQG, so you could get your data from CQG). If you choose to get your data from us, then you would need to be on package 10, 11, or 12, as this authorizes the Denali Exchange Data Feed. Otherwise, if you are not getting the data from us, then you can be on package 3, or 5. Just keep in mind, that if you are not getting the data from us, then you need to be authorized to get the data from CQG. If you are not setup for one or the other, then you will not get any data. You can always change your service package at any time. Only the end date changes. As to why you would want the Denali data, the primary reasons are that the Denali data has historical tick data going back more than 10 years and since the data feed is ours, it is guaranteed to work with Sierra Chart, and should there be an issue, we can resolve it quickly, instead of having to wait for another vendor. In the end, it is your choice. If you let us know how you want to be setup, then we can tell you what package you need and if there are any other setup steps to go through. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-14 16:36:15] |
Мне очень понравился Teton Routing но я торгую в AMP, поэтому будем ждать их положительного решения
[2022-01-14 20:04:53] |
From Google Translate: I really liked Teton Routing, but I trade in AMP, so we will wait for their positive decision
We understand. Just to ensure that there is no confusion - the Denali Exchange Data Feed can be used with any broker, even AMP. You do not have to use it, but it is available. When using the Teton Order Routing you have to use the Denali Exchange Data Feed, since you do not have access to any other data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
