Date/Time: Sun, 15 Feb 2026 05:43:16 +0000
Live order sent on SIM account (ACSIL)
View Count: 1338
| [2014-04-08 14:35:27] |
| VF56002 - Posts: 27 |
I use this code in my strategy // This is false by default. Orders will not go live if disabled on input
if (!SendOrdersToTradingService.GetYesNo()) sc.SendOrdersToTradeService = false; else sc.SendOrdersToTradeService = true; I've got an input created as 'Yes/No' values select box. If I choose 'Yes', order is sent as a simulated order insted of a live order. I keep "Trade Simulation Mode" option not checked. Where could be the problem? Thanks |
| [2014-04-08 17:13:27] |
Based upon the code, it will to what you describe.
