Date/Time: Sun, 15 Feb 2026 04:40:50 +0000
QuoteBoard
View Count: 1242
| [2014-04-08 13:28:38] |
| turnbull - Posts: 34 |
Hi, Is it necessary to keep a particular cart open in order to display values in the quote board?? When I add a new symbol on the board I get all values zero. Values start showing only after opening that particular chart. But if the chart is closed and application is started then again no values unless the chart is re-opened. Thanks |
| [2014-04-08 16:32:53] |
You are using Global Data Feeds. This is an unusual data feed in the way that it works, so what you describe does make sense. You do need to have a chart open. This is only true of Global Data Feeds.
