Date/Time: Sun, 15 Feb 2026 04:28:13 +0000
timer for study function
View Count: 1337
[2014-04-07 22:10:09]
onnb - Posts: 664
Is there a way to have the study function get called every X seconds (regardless of the feed)?
[2014-04-07 22:23:13]
No but this could be developed if it is important.
You can indirectly do it by setting sc.UpdateAlways = 1, and counting the amount of time elapsed from these calls into the function and then take action after a certain amount of time.
Date Time Of Last Edit: 2014-04-07 22:24:05
[2014-04-07 23:18:58]
onnb - Posts: 664
sc.UpdateAlways could be a solution for the time being - I'll follow up if something else is needed.
[2014-04-08 10:54:49]
onnb - Posts: 664
Will this work when SC is disconnected?
[2014-04-08 19:07:00]
Yes.
