Date/Time: Thu, 18 Apr 2024 17:51:37 +0000
Connection problem
View Count: 1371
[2014-04-07 14:39:45] |
User96984 - Posts: 3 |
Having been absent for some 4 months I have trouble connecting to the Interactive Brokers data service. None of my settings have been changed, yet I cannot connect. Can you please assist? Software version: 1115 | 2014-04-07 16:24:31 Usage end date: 2015-04-14 | 2014-04-07 16:24:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-07 16:24:31 Active service: Interactive Brokers | 2014-04-07 16:24:31 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-04-07 16:24:31 2014-04-07 16:24:31 Local computer clock time | 2014-04-07 16:24:31 2014-04-07 14:24:31 GMT time | 2014-04-07 16:24:31 2014-04-07 16:24:31 Time zone adjusted time | 2014-04-07 16:24:31 Time difference to server time: 1 seconds. | 2014-04-07 16:24:31 Program path: C:\SierraChart\ | 2014-04-07 16:24:31 Data Files path: C:\SierraChart\Data\ | 2014-04-07 16:24:31 OS Version Number: 6.1 | 2014-04-07 16:24:31 Checking for new symbol settings for ib | 2014-04-07 16:24:31 Symbol settings are up-to-date for ib | 2014-04-07 16:24:31 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 16:24:36 The network socket is connected. | 2014-04-07 16:24:36 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 16:24:36 TWS server version: 67 | 2014-04-07 16:24:36 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 16:24:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 16:24:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 16:24:36 Socket has been shutdown and closed. | 2014-04-07 16:24:36 Disconnected from IB. | 2014-04-07 16:24:36 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 16:24:36 Starting TWS auto-login thread. | 2014-04-07 16:24:40 TWS auto-login thread ending. | 2014-04-07 16:24:40 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 16:24:41 The network socket is connected. | 2014-04-07 16:24:41 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 16:24:41 TWS server version: 67 | 2014-04-07 16:24:41 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 16:24:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 16:24:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 16:24:41 Socket has been shutdown and closed. | 2014-04-07 16:24:41 Disconnected from IB. | 2014-04-07 16:24:41 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 16:24:41 Starting TWS auto-login thread. | 2014-04-07 16:24:44 TWS auto-login thread ending. | 2014-04-07 16:24:44 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 16:24:46 The network socket is connected. | 2014-04-07 16:24:46 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 16:24:46 TWS server version: 67 | 2014-04-07 16:24:46 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 16:24:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 16:24:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 16:24:46 Socket has been shutdown and closed. | 2014-04-07 16:24:46 Disconnected from IB. | 2014-04-07 16:24:46 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 16:24:46 Starting TWS auto-login thread. | 2014-04-07 16:24:48 TWS auto-login thread ending. | 2014-04-07 16:24:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 16:24:51 The network socket is connected. | 2014-04-07 16:24:51 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 16:24:51 TWS server version: 67 | 2014-04-07 16:24:51 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 16:24:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 16:24:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 16:24:51 Socket has been shutdown and closed. | 2014-04-07 16:24:51 Disconnected from IB. | 2014-04-07 16:24:51 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 16:24:51 Starting TWS auto-login thread. | 2014-04-07 16:24:52 TWS auto-login thread ending. | 2014-04-07 16:24:52 Starting TWS auto-login thread. | 2014-04-07 16:24:56 TWS auto-login thread ending. | 2014-04-07 16:24:56 |
[2014-04-07 17:55:41] |
You need to update Trader Workstation with this download link: https://download2.interactivebrokers.com/download/tws40_install_latest.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-07 18:27:57] |
I had done this already (and now did it again). TWS confirms it is the latest version I have installed. Sierra stil does not connect. Regards, Ron Software version: 1115 | 2014-04-07 20:24:59 Usage end date: 2015-04-14 | 2014-04-07 20:24:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-07 20:24:59 Active service: Interactive Brokers | 2014-04-07 20:24:59 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-04-07 20:24:59 2014-04-07 20:24:59 Local computer clock time | 2014-04-07 20:24:59 2014-04-07 18:24:59 GMT time | 2014-04-07 20:24:59 2014-04-07 20:24:59 Time zone adjusted time | 2014-04-07 20:24:59 Time difference to server time: 0 seconds. | 2014-04-07 20:24:59 Program path: C:\SierraChart\ | 2014-04-07 20:24:59 Data Files path: C:\SierraChart\Data\ | 2014-04-07 20:24:59 OS Version Number: 6.1 | 2014-04-07 20:24:59 Checking for new symbol settings for ib | 2014-04-07 20:24:59 Symbol settings are up-to-date for ib | 2014-04-07 20:25:00 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:04 The network socket is connected. | 2014-04-07 20:25:04 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:04 TWS server version: 67 | 2014-04-07 20:25:04 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:04 Socket has been shutdown and closed. | 2014-04-07 20:25:04 Disconnected from IB. | 2014-04-07 20:25:04 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:04 Starting TWS auto-login thread. | 2014-04-07 20:25:08 TWS auto-login thread ending. | 2014-04-07 20:25:09 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:09 The network socket is connected. | 2014-04-07 20:25:10 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:10 TWS server version: 67 | 2014-04-07 20:25:10 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:10 Socket has been shutdown and closed. | 2014-04-07 20:25:10 Disconnected from IB. | 2014-04-07 20:25:10 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:10 Starting TWS auto-login thread. | 2014-04-07 20:25:12 TWS auto-login thread ending. | 2014-04-07 20:25:12 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:15 The network socket is connected. | 2014-04-07 20:25:15 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:15 TWS server version: 67 | 2014-04-07 20:25:15 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:15 Socket has been shutdown and closed. | 2014-04-07 20:25:15 Disconnected from IB. | 2014-04-07 20:25:15 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:15 Starting TWS auto-login thread. | 2014-04-07 20:25:16 TWS auto-login thread ending. | 2014-04-07 20:25:16 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:20 The network socket is connected. | 2014-04-07 20:25:20 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:20 TWS server version: 67 | 2014-04-07 20:25:20 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:20 Socket has been shutdown and closed. | 2014-04-07 20:25:20 Disconnected from IB. | 2014-04-07 20:25:20 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:20 Starting TWS auto-login thread. | 2014-04-07 20:25:20 TWS auto-login thread ending. | 2014-04-07 20:25:20 Starting TWS auto-login thread. | 2014-04-07 20:25:25 TWS auto-login thread ending. | 2014-04-07 20:25:25 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:25 The network socket is connected. | 2014-04-07 20:25:25 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:25 TWS server version: 67 | 2014-04-07 20:25:25 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:25 Socket has been shutdown and closed. | 2014-04-07 20:25:25 Disconnected from IB. | 2014-04-07 20:25:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:25 Starting TWS auto-login thread. | 2014-04-07 20:25:29 TWS auto-login thread ending. | 2014-04-07 20:25:29 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-04-07 20:25:30 The network socket is connected. | 2014-04-07 20:25:30 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-04-07 20:25:30 TWS server version: 67 | 2014-04-07 20:25:30 IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-04-07 20:25:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-07 20:25:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-07 20:25:30 Socket has been shutdown and closed. | 2014-04-07 20:25:30 Disconnected from IB. | 2014-04-07 20:25:30 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-07 20:25:30 File >> Disconnect selected. | 2014-04-07 20:25:32 Disconnected from IB. | 2014-04-07 20:25:32 |
[2014-04-07 18:30:51] |
This log is indicating you are running a version of Trader Workstation which is less than version 939.2. That is quite clear. If you need help with getting version 939.2 or higher then please contact Interactive Brokers. Maybe you might want to uninstall Trader Workstation from your computer and reinstall using the link we gave. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-07 21:23:56] |
Looks OK now, thanks a lot. Ciao, Ron van Beaumont |
