Date/Time: Sat, 20 Apr 2024 05:00:14 +0000
Will not allow me to connect to TT FIX >> Please help!
View Count: 1007
[2014-04-06 03:25:08] |
User37129 - Posts: 15 |
Hi there SC Staff, For the past couple of days, I have been able to connect to TT FIX successfully, but since Saturday morning (5 April), I have not been able to connect to TT FIX, this is the message I am getting: "TT FIX: Connecting. | 2014-04-05 23:07:44 Starting the Price Feed session. Connecting to 208.95.248.77 port 10502... | 2014-04-05 23:07:44 The network socket is connected. | 2014-04-05 23:07:44 HD Request # 3 - Sending historical data logon request message. | 2014-04-05 23:07:44 HD Request # 3 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-04-04 18:05:46. Record interval: 1 | 2014-04-05 23:07:45 Socket has been shutdown and closed. | 2014-04-05 23:07:45 The network socket for historical data has been closed. | 2014-04-05 23:07:45 HD Request # 3 - Historical data for NQ-201406-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-04-05 23:07:45 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201406-CME | 2014-04-05 23:07:45 HD Request # 3 - Intraday download COMPLETE for NQ-201406-CME | 2014-04-05 23:07:45 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-04-05 23:07:46 Socket has been shutdown and closed. | 2014-04-05 23:07:46 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2014-04-05 23:07:46 Disconnected from TT FIX Price Feed session. | 2014-04-05 23:07:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-05 23:07:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-05 23:07:46 TT FIX: Disconnected. | 2014-04-05 23:07:46 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-05 23:07:46 TT FIX: Connecting. | 2014-04-05 23:07:51 Starting the Price Feed session. Connecting to 208.95.248.77 port 10502... | 2014-04-05 23:07:51 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-04-05 23:07:56 Socket has been shutdown and closed. | 2014-04-05 23:07:56 TT FIX Data: Socket connection was closed without any logout messages sent or received. | 2014-04-05 23:07:56 Disconnected from TT FIX Price Feed session. | 2014-04-05 23:07:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-05 23:07:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-05 23:07:56 TT FIX: Disconnected. | 2014-04-05 23:07:56 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-05 23:07:56 Please help me! Thank You! |
[2014-04-06 04:44:02] |
Refer to the documentation about this at the bottom of this page: https://www.sierrachart.com/index.php?l=doc/TradingTechnologies.php#ServerAvailability Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
