Date/Time: Fri, 29 Mar 2024 13:59:11 +0000
My trade-activity-log is not showing any orders. I'm using the replay/simulation. Please advise.
View Count: 1160
[2014-04-05 03:15:29] |
Auspicatum - Posts: 46 |
I am talking about the "trade activity log"...under the "trades" tab. It's empty even though I've placed several trades during replay. The dates are set from the first date of the chart's data, to today. The settings across the tops *should be* are: All Simulated(or Replay/Backtest, All Acocunts, and Long & Short. However, I can't get that tab to stay on anything other than "Non-Simulated". If I try to select anything else, it will automatically change back to that on it's own! ???? I really have no idea. It worked before an now it doesn't. I did have to re download SC, a few weeks back, and I suppose it hasn't worked since then. It also did this to me the first time I installed SC, and some adjustment was made to fix it( If I remember correctly). So, I'm trying to figure out how to get the log to work. Please Advise ! Thanks again for your time ! |
[2014-04-05 06:41:02] |
Refer to step 4 and 5 in this section here: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Let us know if that resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-08 00:18:19] |
omg. how stupid was that? :) I didn't realize there was an empty box, and that I had to select the symbol. (covering eyes in shame :) Thanks for your time! |
