Date/Time: Tue, 23 Apr 2024 09:58:24 +0000
[User Discussion] - When trying to use Replay, get error "Encountered an improper argument"
View Count: 1025
[2014-04-05 00:40:12] |
User12676 - Posts: 70 |
When I first start Sierra chart and load Replay feature, it works. When I close the replay window and later open it again I get an error "Encountered an improper argument". Then after quiting SC and restarting the program it works again. If I close the replay window after that, again same error and need to restart SC |
[2014-04-05 01:02:14] |
You are on your own with this one as you are using a non-Windows operating system. There is no official support for those at this time. There will be sometime next year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
