Date/Time: Thu, 25 Apr 2024 01:40:58 +0000
point of control (bid ask)
View Count: 1051
[2014-04-05 21:52:33] |
Profile Trader - Posts: 167 |
You might put together a number bar study and make it 405 mins so it gives you a snapshoot of the RTH session. Then go to your price that you have determined is the POC. If the POC is 1861 for Friday (based on TPO/Time) then there were 5822 Market Orders that hit the bid and 6560 that went off at the offer for Friday. |
[2014-04-05 22:28:55] |
We recommend using the Bid Volume versus Ask Volume study on an Intraday chart with the bars set to 1 Day per bar.
