Date/Time: Tue, 23 Apr 2024 10:57:13 +0000
[User Discussion] - Spread sheet exit entire position????
View Count: 1084
[2014-04-04 16:42:55] |
User14682 - Posts: 83 |
If I have multiple entries programmed at 1 lots and accumulate up to 5 total contracts how do I exit all 5 positions on one signal not just 1 contract. If you can help it would be greatly appreciated!!!! Thanks |
[2014-04-04 17:13:17] |
Sawtooth - Posts: 3976 |
The easiest way is probably using cell J29, or you could control the quantity with Cell J26 and use signals in L3, or N3.
[2014-04-04 18:56:37] |
How would I write the code? This is what I currently have and the quantities are set to 1 and I want to exit entire position =OR(AND(AA3<AE3,AA4>AE4),AND(AA3<AG3,AA4>AG4)) |
[2014-04-04 19:21:21] |
I'll assume that formula is for exiting a long position, so I'll create the opposite direction exit also. Put this in J29, and remove formulas in L3 and N3: =IF(J8>0,OR(AND(AA3<AE3,AA4>AE4),AND(AA3<AG3,AA4>AG4)),IF(J8<0,OR(AND(AA3>AE3,AA4<AE4),AND(AA3>AG3,AA4<AG4)),FALSE)) If you have Signal Only On Bar Close set to Yes, you'll need to increment the rows 1 row higher: =IF(J8>0,OR(AND(AA4<AE4,AA5>AE5),AND(AA4<AG4,AA5>AG5)),IF(J8<0,OR(AND(AA4>AE4,AA5<AE5),AND(AA4>AG4,AA5<AG5)),FALSE)) Date Time Of Last Edit: 2014-04-04 19:24:09
