Date/Time: Thu, 28 Mar 2024 14:03:48 +0000
Volume bar chart question
View Count: 961
[2014-04-04 12:25:04] |
User22396 - Posts: 191 |
I want to have 3 volume charts (volume per bar) that reset at the start of every day, week, (i.e. start of globex session sunday evening) and the start of the month...the daily one is easy with checking the "new bar at session start" but the week and month not sure how to handle since if i check "new bar at session start" then the volume bars are incomplete but if i uncheck then the bar will carry over from friday to sunday evening etc... |
[2014-04-04 16:31:31] |
This is not supported.
