Date/Time: Fri, 19 Apr 2024 08:44:09 +0000
Bid & Ask Depth Bars
View Count: 1091
[2014-04-03 02:56:23] |
Bad Dog - Posts: 17 |
I would like to be able to adjust the number of levels of depth used to calculate the depth bar. Could that feature be added to the study? If not, could the code for the study be made available so I could make my own modifications? Thanks -BD |
[2014-04-04 09:54:29] |
No. This is not possible without a significant amount of work which we are not willing to do.
