Date/Time: Thu, 25 Apr 2024 00:58:50 +0000
Chart trade - open orders
View Count: 557
[2021-10-20 07:43:45] |
aelagha - Posts: 31 |
Hi there, Is it possible to hide open position (working order) trade lines on specific charts? i.e. I have hourly, daily and weekly charts. When I place an order, I want the order lines (entry, stop and target lines to show only on the hourly and daily but not the weekly. Thanks |
[2021-10-20 14:46:27] |
John - SC Support - Posts: 31098 |
Refer to the following setting: Trade Menu: Only Orders From Chart (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-20 16:34:14] |
That is global for all charts. Either show the orders in chart that the orders were placed from, or all charts. You can enable/disable this per chart. No worries. it is not a big deal anyways. thansk |
[2021-10-20 17:42:34] |
That setting is NOT global for all charts, it is a per chart option. Set it for one chart, then change to another and you will see that it is not set on that other chart. Whichever chart is active will reflect the state when you select the menu.
