Date/Time: Sat, 20 Apr 2024 10:56:38 +0000
Transfer Spreadsheet(s) System for trading to new installation problem
View Count: 357
[2021-10-20 00:28:58] |
User612901 - Posts: 25 |
Hi I have bought a new computer that I will use for SC Have followed steps under Help Topic 15. All is good except my spreadsheets have no foumulae in them. The workaound I have found is to - remove the spreadsheet from Studies to Graph - Add a new Spreadsheet System for Trading to the Studies to Graph - Select the Spreadsheet again and Apply>OK This then appplies the spreadsheet.... with formulae now. Problem: - I have a large number of spreadsheets Is there a quicker way to ensure spreadsheets contain the formulae whe I open a Chartbook? Some sort of bulk process to be applied to all .scss files? Thanks in advance |
[2021-10-20 00:33:30] |
You should not have any problem like this. So you open a Spreadsheet file that should contain formulas and the formulas are not there? What was saved in that spreadsheet will still exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-21 06:49:30] |
For clarity, I open a chartbook(s) with .cht and .scss. as before, the spreadsheet exists and opens, but no formulae..... only solution I have found is as described previously... but have a lot of spreadsheets agreed what was saved in spreadsheet still exists, but only if i go through process described.... was hoping for a faster solution that could be applied to all spreadsheets |
[2021-10-21 13:12:40] |
John - SC Support - Posts: 30976 |
Are you using a specific Formula Source Sheet that is different from the sheet number? Can you attach a chartbook and spreadsheet file for us to see if we can reproduce your situation? Follow these instructions to attach the files: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
