Date/Time: Fri, 29 Mar 2024 11:00:34 +0000
Tick size doesn't copy over when duplicating chart
View Count: 493
[2021-10-16 14:26:06] |
User34124 - Posts: 266 |
Hi I've long since noticed this, and it seems an inconsistency given all other chart features are copied over. Could this be fixed as a low priority?
[2021-10-17 18:28:23] |
Sierra_Chart Engineering - Posts: 13625 |
This may actually get set from the Global Symbol Settings when duplicating a chart.
[2021-10-18 10:41:57] |
That's not the same functionality. It's different from merely getting copied when the chart is duplicated, like every other feature is.
[2021-10-21 08:04:45] |
User90125 - Posts: 715 |
On the Chart Setting window, under the Main Settings tab, there is a checkbox for "Auto Set from Data Feed". See if this is the cause of the inconsistency.
