Date/Time: Wed, 24 Apr 2024 00:57:24 +0000
DOM not populating
View Count: 1111
[2021-10-26 15:27:37] |
Drew1904 - Posts: 26 |
Today’s a bad day as i was supposed to be migrating to a new machine. But, for whatever reason Lenovo is saying that it hasn’t left the warehouse yet when it was supposed to be next day air. Standy until i get resolution please. |
[2021-10-26 15:35:39] |
Ok no worries. Just let us know.
[2021-10-27 20:18:15] |
Quick question (still waiting on the new machine) - is it better to import the entire SC file or to get a fresh install? Or alternatively dump all the chart data and just import the files less intraday and daily charts? |
[2021-10-28 14:52:31] |
We definitely recommend just copying your existing Sierra Chart installation and excluding the Intraday data files with a scid extension. For more information, refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-28 14:52:36
[2021-11-04 00:07:26] |
Alright, so i've successfully gotten everything sorted and migrated onto a new machine. The issue is still there but, for whatever reason, randomly, one DOM will populate out of the three separate downloads. Sometimes in a new instance, sometimes in the main instance. This coupled with the P/L tracking issue i'm having is leading me to believe something is wonky with the actual install/original files as I'm on a completely new machine now. |
[2021-11-05 04:05:23] |
Sierra_Chart Engineering - Posts: 14064 |
Contacted user and resolved outstanding issues.
