Date/Time: Thu, 28 Mar 2024 18:02:04 +0000
intraday data with rithimic
View Count: 749
[2021-10-12 14:48:38] |
User740715 - Posts: 26 |
I made the manipulation to have the intraday data with the denali exhange and rithmic it does not work how can I close my sierra chart account
[2021-10-12 16:51:03] |
John - SC Support - Posts: 30434 |
In order to get the Non-Professional CME Data, you need to connect to a live, funded, futures trading account. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges As part of this, you need to enter the information for that account in the Uniform Subscriber Agreement that you complete as part of setting up the Denali Exchange Data Feed. You have not supplied the information we need in order to be able to qualify you as a non-professional. Keep in mind that the prop trading firms do not count as a live trading account as far as the CME Group is concerned, so you can not use that as your account information in the agreements. If you do not have a trading account, then we recommend the following service: Easy Solution to CME Funded Trading Account Requirement --------------------- If you just want to close out your account, then refer to the following: Sierra Chart Purchase and License Information: Canceling For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-12 18:09:20] |
you don't understand my problem i use the rithmic paper trading server with a leeloo trading performance account last week everything was working and since monday the intraday data no longer load i performed all the manipulation indicated on your media to correct the error but nothing works I ask you to solve my problem it is useless to send me to support links it does not work if you can not help me I would turn to another platform
[2021-10-12 18:22:37] |
[2021-10-12 19:32:21] |
We are not able to solve this issue, due to market data rules. This is out of our control. We will need to issue you a refund. But we cannot refund the exchange fee. Confirm if you would like the refund or if you want to use Sierra Chart with a supported service other than Rithmic. The supported services are here: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-12 19:32:52
[2021-10-13 14:56:05] |
mon probleme est simple porquoi les donnees intraday ne fonctionne plus les donnees dayli et le dom fonctionne je souhaite me connecter avec Leeloo trading pourriez vous m aider
[2021-10-13 16:38:03] |
From Google Translate my problem is simple why the intraday data no longer works the dayli data and the dom works I want to connect with Leeloo trading could you help me
We are trying to help you, but as much as you think this is simple, it is just is not. You are wanting to use the Denali Exchange Data Feed for the CME Group data. But in order to get the data for the CME Group at the non-professional exchange rates, you need to have a live, funded, futures trading account that can be verified each month. Your account with LeeLoo does NOT count towards this requirement. Therefore, if you want to get the non-professional exchanges, you would need to connect to a different account that is not a prop firm. This is the information we gave you in Post #2. If you are looking for a simple solution that does not involve opening an account, then that answer is to pay the Professional exchange fees. Keep in mind - these are not our rules - we are just enforcing the rules put upon us by the CME Group. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 16:52:02] |
la semaine derniere tout fonctionnait parfaitement depuis lundi ca ne fonctionne plus aidez moi a comprendre
[2021-10-13 16:56:28] |
From Google Translate: last week everything was working perfectly since Monday it no longer works help me understand
We do not know what was occurring last week. Definitely you were not using the Denali Exchange Data Feed for the data, as your status with regards to the Denali Data has not changed. The only thing we can think is that perhaps you were looking at the Delayed Streaming Data rather than the real-time data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 17:02:30] |
j utilise denaily exchange pack 11 avec rithmic pour faire fonctionner mon compte Leeloo trading avec le serveur paper trading depuis lundi les donnees dayly fonctionne le dom fonctionne mais les donnees intraday ne fonctionnes plus les graphiques reste bloques sur download continus contract et ne charge pas avez vous mis a jour cette connection avec rithimic
[2021-10-13 17:45:34] |
From Google Translate: I use denaily exchange pack 11 with rithmic to make my Leeloo trading account work with the paper trading server since Monday the dayly data works the dom works but the intraday data does not work anymore the charts remain blocked on continuous download contract and do not load you updated this connection with rithimic
At this point you will need to decide whether you want to use the Rithmic data, which has a lack of historical data, or the Denali Exchange Data Feed, which will require you to have a separate trading account. Once you decide on which one you want to use, then we can help you get everything setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 17:53:22] |
c est pas la question on ne peux vraiment pas compter sur vous toujours des reponses a cote bravo sierra on peut dire que vous soutenez votre communaute merci !!!!!!!!!!!!!
[2021-10-13 18:17:44] |
From Google Translate: that's not the question we really can't count on you always answers to side bravo sierra we can say that you support your community thank you !!!!!!!!!!!!!
Sorry, but we are not understanding what you are trying to tell us, apart from the fact that you are unhappy with us. But, we are only working within the rules of what has been set by the CME Group. We are not making this hard because we want to, it is the rules of the exchanges that is creating this situation. If you do not want to use the Denali Exchange Data Feed, then we are happy to help you get setup again with the Rithmic data. Just let us know what you want to do so we can direct you properly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-14 14:47:56] |
je souhaite que vous m aidiez a corriger mon probleme je travail avec rithmic (rtrader pro) avec un compte Leeloo trading depuis lundi les donnees intra journalieres ne fonctionnent plus ;la connection se fait les donnees dayli marchent et le Dom aussi mais aucun graphique intrday ne chargent pouvez vous m aidez
[2021-10-14 14:57:34] |
voici une capture
Capture d’écran 2021-10-14 165557.jpg / V - Attached On 2021-10-14 14:56:25 UTC - Size: 343.54 KB - 116 views Attachment Deleted. |
[2021-10-14 16:48:24] |
We are going to issue you a refund because we cannot help you due to CME market data policy.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-14 16:48:30
[2021-10-14 17:14:30] |
I don't understand it is not a question of refunding me why I haven't had any intraday data since Monday do you UNDERSTAND or not what is your problem ??????????
[2021-10-14 17:15:32] |
why don't you support your users ????????????????????????????????????????????
[2021-10-14 17:17:06] |
I tell you that since Monday my intraday charts don't work anymore the rest works why you don't help me to solve this problem ?????????????
[2021-10-14 17:17:56] |
File attached
Capture d’écran 2021-10-14 165557.jpg / V - Attached On 2021-10-14 17:17:48 UTC - Size: 343.54 KB - 124 views |
[2021-10-14 17:49:17] |
We have cancelled your services and will issue you a refund to your card within the next day or two.
[2021-10-15 02:46:21] |
Sierra_Chart Engineering - Posts: 13609 |
You need to understand the horror of CME market data policy: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Everything you need to know is there. We do not help with Rithmic market data issues and they do not have working or acceptable historical data and you need to use our Denali data feed and the CME requires you have a normal live funded trading account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-15 02:51:42
