Date/Time: Tue, 23 Apr 2024 06:42:50 +0000
Custom symbols not working with numbers
View Count: 538
[2021-10-11 19:39:40] |
Matt NL - Posts: 91 |
Could someone please help me get a simple test custom symbol working? It seems whenever I use a multiplier it fails. For example, this works ok... {X.US.VOLQ}-{X.US.VOLI} But this fails... 2*{X.US.VOLQ} Log file states: 2*{X.US.VOLQ}-{X.US.VOLI} Daily #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\2%{X.US.VOLQ}-{X.US.VOLI}.dly | 2021-10-11 14:36:06.286 But it doesn't download anything or do anything further. What am I doing wrong? Thanks Matt |
[2021-10-12 18:40:00] |
Sierra_Chart Engineering - Posts: 14052 |
Custom calculated symbols do not work with historical Daily charts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-12 18:40:06
[2021-10-12 19:35:35] |
Thank you but I also tried intraday. Here's a complex example that's working perfectly... {X.US.SDEX}/average({X.US.VOLI},{X.US.VOLQ}) But if I do this (adding 2* at the beginning)... 2*{X.US.SDEX}/average({X.US.VOLI},{X.US.VOLQ}) ..it won't work. Just wondering if I'm doing something wrong. Another question... if I go offline / computer on standby during the day, when I come back and reconnect my data it won't pull down the missing data from when I was offline. So I get a gap in the middle. I can fix this by deleting and re-downloading all data again, but I don't want to lose all my historical data. Is there any reason why this might be happening? Thanks Matt |
[2021-10-13 20:12:14] |
1. We will check on this. 2. if I go offline / computer on standby during the day, when I come back and reconnect my data it won't pull down the missing data from when I was offline. So I get a gap in the middle. I can fix this by deleting and re-downloading all data again, but I don't want to lose all my historical data. Is there any reason why this might be happening? It sounds like one or more of the historical data downloads are failing.You only need to follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-13 20:12:35
[2021-10-13 20:34:09] |
We tested this and did not encounter a problem: 2*{EURUSD}-{EURGBP} So we do not know what the issue is in your case. We cannot test those symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-14 08:37:43] |
Sorry I stand corrected... it now works! I've no idea why it now works, I didn't change anything. It might be because it's a new symbol at CQG which they hadn't 100% finished adding or something. I'll check later if the missing data problem is also fixed (it's only during market hours so I'll have to get back to you). Thanks again |
[2021-11-02 14:50:28] |
joshtrader - Posts: 439 |
I also experienced this same issue, and wanted to make a record of it here. This works: {F.US.ENQZ21}-{F.US.YMZ21}
This doesn't: 5*{F.US.ENQZ21}-9*{F.US.YMZ21}
What I did was restarted SC. It may be something with the sequence of events (downloading of historical data, etc.). So, if you experience this issue, try stopping SC, deleting the file (carefully) which is in the data directory, and starting again. |
spreads.png / V - Attached On 2021-11-02 14:23:43 UTC - Size: 6.48 KB - 120 views |
[2021-11-02 15:04:02] |
Excellent, thanks for the tip. I'll try that next time. Glad I wasn't going crazy lol
