Date/Time: Thu, 28 Mar 2024 22:50:57 +0000
My data is delayed.
View Count: 574
[2021-10-05 13:13:44] |
Trade The Nine - Posts: 31 |
My charts have been down since yesterday with delayed data. I've added my IB account for futures, signed the agreements. What am I missing? Please advise. Thank you.
[2021-10-05 13:29:52] |
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 13:50:05] |
Thank you for the link. I added my IB account yesterday, did it not clear the verification? Also, my US equities is delayed, is this connected to my current issues?
[2021-10-05 17:36:35] |
John - SC Support - Posts: 30444 |
First, let's look at the U.S. Equities. You should not be having any issues with the U.S. Equities. They should be coming in real-time. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. -------------------- Are you wanting to get data for the CME Group as well? If so, then you need to go through these Setup Instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* You have some of the items done, but not all of them. Please go through all of the instructions and ensure that everything is done as laid out in the instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 18:00:33] |
Thank you for the reply John. I believe I've found the source of the delayed Equities data. Looks like I'm still classified as a Professional. My previous email was the reason of the Pro tag. I have updated my email and resubmitted the exchange agreements. What is the ETA to correct my status to non Professional and have my US data back to real-time? Thank you for the help. |
ProStat.png / V - Attached On 2021-10-05 17:59:08 UTC - Size: 481.69 KB - 140 views WebLog.png / V - Attached On 2021-10-05 17:59:14 UTC - Size: 376.54 KB - 111 views |
[2021-10-05 18:24:39] |
You are correct, it is the Professional status. We have sent an email to our provider for this data to find out the status of your resubmission of the agreements. As soon as we hear back, we will let you know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-05 20:00:16] |
My status has been updated to Non Professional, but data is still delayed. I've disconnected and reconnected from data as well as shut down Sierra.
[2021-10-05 22:37:17] |
Effective tomorrow morning, you will begin to receive real-time data for US equities.
