Date/Time: Wed, 19 Aug 2026 23:39:20 +0000
[User Discussion] - Windows 8.1
View Count: 1565
| [2014-03-25 17:20:53] |
| Carol Rutherford - Posts: 66 |
i just purchased a new computer which came with Windows 8.1 What malware or other security software would you suggest I use that won't interfere with Sierra Charts. I haven't put any thing on yet because I don't want to cause a potential problem with interference. Carol Rutherford |
| [2014-03-25 17:26:57] |
We will leave this to other users to comment on.
| [2014-09-12 23:19:32] |
| jsoviero - Posts: 84 |
I am also considering to purchase a new computer which will be running Windows 8.1 and use "touch screen" enabled monitors. As a long time loyal SC subscriber, I would like some opinion or guidance on this possibility from Sierra Support. TY in advance. Other users also welcome to add opinions or actual experiences.
| [2014-09-13 10:16:24] |
| Spinoza - Posts: 62 |
I just use Windows Defender which is free, effective and never caused any problems with SC
| [2014-09-13 22:14:39] |
| User120827 - Posts: 77 |
windows defender for me as well with no problems.
| [2014-09-13 23:24:08] |
| User64662 - Posts: 15 |
I use two 8.1 with Sierra Charts At for 5 weeks now. One unit wireless in family room while I rest. I have seen no issues with 8.1. Two other units are Win 7 and run them side by side laptops connected to two 39 inch LCD Vizio tv screens. I'm very happy with SC. I have used and still run other platforms as well for years. They run the same on Win 8 and 7. Defender M Essentials fine as well so far. Light weight runs like a Triple Crown Thoroughbred. Quick loading of different symbols excellent and I don't have to fight adjusting charts. It takes time and patience to learn that's why I read the support forum threads. |
| [2014-09-14 12:27:46] |
| moonmist - Posts: 127 |
Hi, Some people complain that many popular programs cannot run on Windows 8 due to tightened security. Have you guys encountered similar problems ? Thanks. PS: I also learn a lot from reading the posts on this support board. Date Time Of Last Edit: 2014-09-14 13:11:05
| [2014-09-14 20:34:36] |
Nothing I have seen with programs. Only issue I have had with a Toshiba laptop quad core 8 ram. This unit must have came out with the first 8.1. Setting up keyboard was sending out wrong key strokes. Researching online that it is an issue I found. I use the on screen keyboard on Win 7 and 8. On an HP that I upgraded from 8 to 8.1 no issue with keyboard. Personally I like Linux systems but limited with trading with some programs. I don't spend much on my computers and I won't buy an OS unless bundled with a new laptop. The HP versus the Toshiba program is different a bit. The design of chimes and layout 8.1 I don't care for. Linux rocks. Good luck best to try 8.1 and take a test drive in a store. |
