Date/Time: Thu, 28 Mar 2024 20:28:11 +0000
[User Discussion] - Mouse Scroll Acceleration
View Count: 2579
[2014-03-22 13:09:29] |
maxima120 - Posts: 144 |
I would really like a mouse scroll acceleration.. for example - if it is a single 'click/notch' of the mouse wheel - it scrolls a chart to 1 bar. but if there is large number of clicks - then the speed grows exponentially. it is almost impossible to scroll charts the way I want. I found myself dragging the scrollbar more often.. Either way it is very uncomfortable and inefficient. Changing the Windows settings for the mouse breaks almost every other Windows apps on the machine. I will appreciate if you could change that bit of the behaviour. Thank you |
[2014-03-22 21:33:41] |
vegasfoster - Posts: 444 |
How do you have your tools setup? If you set Tools >> Tool Settings >> General Tab >> After Single Tool Use Change To: Hand, and then check the box for Tools >> Tool Settings >> Chart Values Tab >> Crosshair Style >> Always On When Using Other Tools, then you can just grab the screen and quickly move it where you want to go without having to do a bunch of scrolling and you will still have your crosshairs on all the time. To me it's the easiest way anyway :)
[2014-03-23 00:45:51] |
yeah thats cool but still not what i need. thanks though
