Date/Time: Thu, 25 Apr 2024 13:07:01 +0000
how to split the profit target line into two different profit target lines of a single contract
View Count: 1757
[2014-03-22 21:55:51] |
This is not supported. It is not possible to split an order. You have to cancel the Attached Orders. Reconfigure the Attached Orders to set 2 Targets. And then resend them using the Send Attached Orders feature: https://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#SendAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-23 03:37:54] |
Yes here is an example: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#AttachedOrdersExamples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
