Date/Time: Thu, 25 Apr 2024 07:28:06 +0000
Delta by Price minimum filter
View Count: 1175
[2021-08-07 03:39:26] |
User864733 - Posts: 12 |
Hi I am wondering if it is possible to set a minimum filter for a delta by price study? not just the text value but if say I set a value of 100 then no bar would be printed at a level unless the delta is greater than +100 or less than -100?
[2021-08-09 13:48:48] |
John - SC Support - Posts: 31098 |
We are not sure which study you are referring to. Please give us the exact name of the study so we can be sure we are responding properly.
[2021-08-09 14:35:52] |
Ackin - Posts: 1865 |
"We are not sure which study you are referring to. Please give us the exact name of the study so we can be sure we are responding properly." Volume By Price Study aka VbP I am with the author of this question in Discord communication You have added Input In: 125 to VbP, the user asks you if this could be for individual horizontal bars as well. In other words, be able to display only extreme horizontally bars in the profile according to a user-defined number..... also for Delta ideally Filtered/Hide current horizontally bar If user number >= absolute value(Volume horizontally bar Value) Date Time Of Last Edit: 2021-08-09 14:45:21
[2021-08-09 15:39:32] |
Thank you Ackin for the information. This is not currently supported. We have tagged this thread as a Feature Request, so we will add this to our list of work, but we can not make any commitments on when/if this specific change will happen. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-09 17:07:24] |
I understand .... Would it be possible to add another VbP request to your wishlist? Adding input to extend the color scheme. Please see the attached image. Thank you |
SierraChart_64_SLDk3zsVID.png / V - Attached On 2021-08-09 17:05:40 UTC - Size: 70 KB - 254 views |
[2021-08-09 17:39:06] |
Thank you all for your help!
[2021-08-09 17:56:50] |
Of course Ackin. We always appreciate the requests. But you also know how long it can take for us to get to some of them.
[2022-04-21 08:38:44] |
John - SC Support) Any news on this request? |
[2022-04-21 14:43:09] |
Sorry, but we have not been able to get to it. Just too much to do.
[2023-01-29 18:42:46] |
OrbitalD - Posts: 29 |
Adding request for this feature as well. Thxs!
