Date/Time: Fri, 19 Apr 2024 07:01:56 +0000
Stock quotes
View Count: 458
[2021-08-03 17:03:35] |
Robert Wojczak - Posts: 143 |
How do I get real time stock quotes and what is the cost thanks
[2021-08-03 17:36:45] |
John - SC Support - Posts: 30953 |
To get real-time data for U.S. Stocks, you would need to use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange. Refer to the following, which also includes the Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 11:51:09] |
so my Denali exchange doe not let me get real time equity quotes?
[2021-08-05 14:49:52] |
No, the U.S. Equities are part of the Sierra Chart Exchange Data Feed. We are working on a new U.S. Equities interface that will eventually be part of the Denali Exchange Data Feed, but that project is probably 3-4 months from being available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-17 10:31:59] |
Are equities part of of the Denali Exchange Data feed yet? Thank you
[2022-05-17 10:33:35] |
Yes. This can be obtained through the new NASDAQ TotalView data feed: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Set up instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-17 10:33:55
