Date/Time: Thu, 18 Apr 2024 14:58:06 +0000
Vulume MA line
View Count: 479
[2021-07-16 05:01:53] |
Enzotrading21 - Posts: 4 |
Hi, How can I overlay a volume MA line on top of volume bars at the bottom of chart ? Thanks & appreciate your help |
[2021-07-16 09:41:49] |
SC Support Tom - Posts: 450 |
1) Add the Volume study to a chart. Volume If this is the only study applied to the chart, then this study will be in Chart Region 2. Chart Studies: Settings and Inputs Tab >> Chart Region 2) Add the Moving Average - Simple study to the same chart. Moving Average - Simple In the Settings for this study, set Input Data to Volume, and set Chart Region to 2. I have attached an image of an example of this. |
EURUSD[M] 1 Min #1 2021-07-16 04_39_24.467.png / V - Attached On 2021-07-16 09:41:46 UTC - Size: 35.61 KB - 154 views |
[2022-05-18 17:39:12] |
User566250 - Posts: 24 |
Hello, I am not able to add a exponential moving average to volume indicator correctly, it almost seems like it does not sit correctly on volume, usually too far above it. I have played with scaling and it doesn't help. Please compare the screenshots below for the same exponential MA settings. Thank you |
Screenshot 2022-05-18 133720.jpg / V - Attached On 2022-05-18 17:37:39 UTC - Size: 29 KB - 92 views Screenshot 2022-05-18 133802.jpg / V - Attached On 2022-05-18 17:38:13 UTC - Size: 11.34 KB - 88 views |
[2022-05-18 18:10:36] |
John - SC Support - Posts: 30936 |
Make sure your Moving Average is based on the Volume study and that the Input is the Volume. Refer to the following for Based On: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-18 18:22:29] |
Thanks John. I have it set on Volume, but still not getting a correct MA in relation to Volume itself:
Screenshot 2022-05-18 141850.jpg / V - Attached On 2022-05-18 18:22:19 UTC - Size: 154.29 KB - 91 views |
[2022-05-18 21:09:17] |
Make sure the scale for the Moving Average is set to Same as Region. Refer to the following: Chart Scale and Scale Adjusting: Same As Region (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-18 22:45:57] |
Thank you. Looks like Volume automatically is set on Automatic zero based. I switched that to Auto and set the MA to Same as Region and works great now.
