Date/Time: Fri, 19 Apr 2024 19:46:36 +0000
Nymex datafeed (delayed)
View Count: 470
[2021-07-12 13:51:06] |
Rollmops64 - Posts: 6 |
Hi there, I have the Service Package 5 with the delayed datafeed. Everything works fine except that the Nymex Products like Crude Oil, are all freezed. When I open the Trading Platform at 8am the Charts only laod till 8am and than they freeze. Everything works fine in the other exchanges except Nymex. I don´t know where the problem is. I also installed Sierra again but that doesn´t worked. |
[2021-07-12 14:18:16] |
User146848 - Posts: 120 |
Its started on Friday and happened today again: delayed servers have connection issues while the internet on my end just works fine. After about 20min later everything is fine again.
[2021-07-12 16:40:18] |
John - SC Support - Posts: 30973 |
Does this mean that after 20 minutes everything is showing the delayed data again and your chart with the CL symbol is working correctly? Is the chart still having an issue? The one thing we think this could be is that sometimes when the system has been disconnected from the data feed and then reconnected (like first thing in the morning when you start Sierra Chart) the data download will go all the way to the current time, in which case you would need to wait about 10 minutes before you start to see the delayed data actually updating the chart. Let us know if the above explains it, or if you think you have something else going on, like if the CL continues to stop and start during the day. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-12 17:07:35] |
Its not just Crude Oil. The main instance gets disconnected. The reconnect status (yellow) remains for some time. Doenst matter what server i select. If it happens again tomorrow, then i will post it here. Date Time Of Last Edit: 2021-07-12 17:08:43
[2021-07-12 18:04:12] |
We will need to see the Message Log when it occurs. Follow these instructions to post your Message Log after you have an incident: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-13 06:11:09] |
After waiting 20 Minutes or more it´s still freezed. When I start Sierra it loads the data till this time and than there is no delayed data. But the problem is only with the markets from the Nymex exchange,(Crude Oil (CL)). Message Log: (Log removed) Date Time Of Last Edit: 2021-07-13 09:16:50
[2021-07-13 08:25:59] |
This log is from a sub instance of Sierra Chart. We need to see the Message Log from the main instance of Sierra Chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog And tell us the exact symbol of one of the charts that is not updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-13 08:36:37] |
The Symbol is: CLQ21-Nymex WSAStartup called. | 2021-07-13 07:48:38.291 WSAStartup called. | 2021-07-13 07:48:38.292 WSAStartup called. | 2021-07-13 07:48:38.293 WSAStartup called. | 2021-07-13 07:48:38.294 WSAStartup called. | 2021-07-13 07:48:38.295 WSAStartup called. | 2021-07-13 07:48:38.295 WSAStartup called. | 2021-07-13 07:48:38.296 WSAStartup called. | 2021-07-13 07:48:38.297 WSAStartup called. | 2021-07-13 07:48:38.298 WSAStartup called. | 2021-07-13 07:48:38.298 WSAStartup called. | 2021-07-13 07:48:38.299 WSAStartup called. | 2021-07-13 07:48:38.300 WSAStartup called. | 2021-07-13 07:48:38.300 WSAStartup called. | 2021-07-13 07:48:38.301 WSAStartup called. | 2021-07-13 07:48:38.302 WSAStartup called. | 2021-07-13 07:48:38.303 WSAStartup called. | 2021-07-13 07:48:38.304 WSAStartup called. | 2021-07-13 07:48:38.305 WSAStartup called. | 2021-07-13 07:48:38.305 WSAStartup called. | 2021-07-13 07:48:38.306 WSAStartup called. | 2021-07-13 07:48:38.307 WSAStartup called. | 2021-07-13 07:48:38.308 WSAStartup called. | 2021-07-13 07:48:38.390 Created the DTC Protocol server. | 2021-07-13 07:48:38.392 DTC Protocol Server listening on port 11099. | 2021-07-13 07:48:38.393 Reading Internal Order ID file. | 2021-07-13 07:48:38.394 Reading Trade Orders file. | 2021-07-13 07:48:38.472 Reading Trade Positions file. | 2021-07-13 07:48:38.474 Reading Trade Account Data files. | 2021-07-13 07:48:38.475 WSAStartup called. | 2021-07-13 07:48:38.495 UDPListener (1420). Port 22904 | Listening on UDP port 22904. | 2021-07-13 07:48:38.496 Software version: 2285 64-bit | 2021-07-13 07:48:38.496 Primary Thread ID: 4832 | 2021-07-13 07:48:38.496 Usage end date: 2021-10-24 | 2021-07-13 07:48:38.496 Enabled for: Advanced Features 2. | 2021-07-13 07:48:38.496 Enabled for: Sierra Chart Historical Data Service. | 2021-07-13 07:48:38.496 Enabled for: Delayed Denali Exchange Data Feed. | 2021-07-13 07:48:38.496 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-07-13 07:48:38.496 Current selected Data/Trading service: SC Data - All Services | 2021-07-13 07:48:38.496 Custom symbol settings values: enabled | 2021-07-13 07:48:38.496 Chart Update Interval: 500 | 2021-07-13 07:48:38.496 Intraday Data Storage Time Unit: 0 | 2021-07-13 07:48:38.496 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-07-13 07:48:38.496 2021-07-13 05:48:38 Local computer time in UTC | 2021-07-13 07:48:38.496 2021-07-13 07:48:38 Local computer time in SC Time Zone | 2021-07-13 07:48:38.496 2021-07-13 05:48:37 Server time in UTC | 2021-07-13 07:48:38.496 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-07-13 07:48:38.496 Program path: C:\SierraChart\ | 2021-07-13 07:48:38.496 Data Files path: C:\SierraChart\Data\ | 2021-07-13 07:48:38.496 OS Version Number: 10.0 | 2021-07-13 07:48:38.497 Locale Setting: C | 2021-07-13 07:48:38.497 DLLs: UserContributedStudies_64.dll | 2021-07-13 07:48:38.497 Allowed protected custom studies: | 2021-07-13 07:48:38.497 Created the DTC Protocol historical data server. | 2021-07-13 07:48:38.497 WSAStartup called. | 2021-07-13 07:48:38.497 HD Server Manager | Listening on port 11098. | 2021-07-13 07:48:38.499 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-07-13 07:48:38.500 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:38.560 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:48:38.603 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-07-13 07:48:38.603 Received 5 login tokens. | 2021-07-13 07:48:38.656 Symbol settings MD5 received. Request ID: 1. | 2021-07-13 07:48:39.086 Requested symbol settings for service code scdataallservices. Request ID: 2. | 2021-07-13 07:48:39.086 Symbol settings received. Request ID: 2. | 2021-07-13 07:48:39.837 Files to Open on Startup | Opening file: 6E US-Session Charts.Cht | 2021-07-13 07:48:42.750 6EU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:42.798 6EU21-CME [CB] 15 Min #4 | Performing historical Daily data download for symbol E6U21 starting at last date in file. | 2021-07-13 07:48:42.814 Starting DelayedDownloadMonitoringTimer | 2021-07-13 07:48:42.814 Starting HDTimeoutTimer | 2021-07-13 07:48:42.814 Added historical Daily data request for E6U21 to the queue. | 2021-07-13 07:48:42.814 Triggering next historical data download in queue. | 2021-07-13 07:48:42.814 6EU21-CME [CB] 15 Min #4 | Waiting for historical downloads to complete with the IDs: 1, | 2021-07-13 07:48:42.841 6EU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:42.865 6EU21-CME [CB] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 1, | 2021-07-13 07:48:42.875 6EU21-CME 5 Min #5 | Reloading chart. | 2021-07-13 07:48:42.891 6EU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:42.912 6EU21-CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, | 2021-07-13 07:48:42.947 Files to Open on Startup | Opening file: 6B US-Session Charts.Cht | 2021-07-13 07:48:42.951 6BU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:42.987 6BU21-CME [CB] 15 Min #4 | Performing historical Daily data download for symbol B6U21 starting at last date in file. | 2021-07-13 07:48:43.004 Added historical Daily data request for B6U21 to the queue. | 2021-07-13 07:48:43.004 6BU21-CME [CB] 15 Min #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-07-13 07:48:43.032 6BU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:43.043 6BU21-CME [CB] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 2, | 2021-07-13 07:48:43.055 6BU21-CME 5 Min #5 | Reloading chart. | 2021-07-13 07:48:43.066 6BU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:43.085 6BU21-CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 2, | 2021-07-13 07:48:43.119 Files to Open on Startup | Opening file: GC US-Session Charts.Cht | 2021-07-13 07:48:43.123 GCQ21-COMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:43.142 GCQ21-COMEX [CB] 15 Min #1 | Performing historical Daily data download for symbol GCQ21 starting at last date in file. | 2021-07-13 07:48:43.156 Added historical Daily data request for GCQ21 to the queue. | 2021-07-13 07:48:43.156 GCQ21-COMEX [CB] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 3, | 2021-07-13 07:48:43.189 GCQ21-COMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:43.214 GCQ21-COMEX [CB] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 3, | 2021-07-13 07:48:43.232 GCQ21-COMEX 1 Min #5 | Reloading chart. | 2021-07-13 07:48:43.245 GCQ21-COMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:43.281 GCQ21-COMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 3, | 2021-07-13 07:48:43.327 Files to Open on Startup | Opening file: CL US-Session Charts.Cht | 2021-07-13 07:48:43.332 CLQ21-NYMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:43.353 CLQ21-NYMEX [CB] 15 Min #1 | Performing historical Daily data download for symbol CLQ21 starting at last date in file. | 2021-07-13 07:48:43.373 Added historical Daily data request for CLQ21 to the queue. | 2021-07-13 07:48:43.373 CLQ21-NYMEX [CB] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 4, | 2021-07-13 07:48:43.398 CLQ21-NYMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:43.407 CLQ21-NYMEX [CB] 5 Min #2 | Waiting for historical downloads to complete with the IDs: 4, | 2021-07-13 07:48:43.429 CLQ21-NYMEX 1 Min #5 | Reloading chart. | 2021-07-13 07:48:43.440 CLQ21-NYMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:43.489 CLQ21-NYMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 4, | 2021-07-13 07:48:43.532 Files to Open on Startup | Opening file: ES US-Session Charts.Cht | 2021-07-13 07:48:43.538 ESU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:43.569 ESU21-CME [CB] 15 Min #4 | Performing historical Daily data download for symbol ESU21 starting at last date in file. | 2021-07-13 07:48:43.616 Added historical Daily data request for ESU21 to the queue. | 2021-07-13 07:48:43.616 ESU21-CME [CB] 15 Min #4 | Waiting for historical downloads to complete with the IDs: 5, | 2021-07-13 07:48:43.647 ESU21-CME [CB] 1 Min #2 | Reloading chart. | 2021-07-13 07:48:43.673 ESU21-CME [CB] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 5, | 2021-07-13 07:48:43.688 ESU21-CME 5 Min #5 | Reloading chart. | 2021-07-13 07:48:43.702 ESU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:43.794 ESU21-CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 5, | 2021-07-13 07:48:43.840 Mapping E6U21 to 6EU21. Service code: cme | 2021-07-13 07:48:43.856 HD Request # 1 | Downloading Historical Daily chart data for E6U21. Starting date: 2021-07-08. Service: scdataallservices | 2021-07-13 07:48:43.860 Mapping 6EU21-CME to 6EU21. Service code: cme | 2021-07-13 07:48:43.955 Starting DelayedDownloadMonitoringTimer | 2021-07-13 07:48:43.955 Starting HDTimeoutTimer | 2021-07-13 07:48:43.955 Added historical Intraday data request for 6EU21-CME to the queue. | 2021-07-13 07:48:43.956 Intraday data recording state for symbol 6EU21-CME is set to download 'Pending'. | 2021-07-13 07:48:43.956 Triggering next historical data download in queue. | 2021-07-13 07:48:43.956 HD Request # 2 | Downloading Intraday chart data for 6EU21-CME to the file 6EU21-CME.scid. Service: cme | 2021-07-13 07:48:43.956 HD Request # 2 | Download start date-time: 2021-07-12 19:38:46.000000. File last date-time: 2021-07-12 19:38:46.745000 | 2021-07-13 07:48:43.956 HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2021-07-13 07:48:43.956 Mapping 6BU21-CME to 6BU21. Service code: cme | 2021-07-13 07:48:43.957 Socket (2) | Creating socket. | 2021-07-13 07:48:43.957 Socket (2) | New receive buffer size: 5242880 | 2021-07-13 07:48:43.957 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-07-13 07:48:43.957 Added historical Intraday data request for 6BU21-CME to the queue. | 2021-07-13 07:48:43.957 Intraday data recording state for symbol 6BU21-CME is set to download 'Pending'. | 2021-07-13 07:48:43.957 Triggering next historical data download in queue. | 2021-07-13 07:48:43.957 Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-07-13 07:48:43.959 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-07-13 07:48:43.959 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-07-13 07:48:43.959 Triggering next historical data download in queue. | 2021-07-13 07:48:43.959 Mapping CLQ21-NYMEX to CLQ21. Service code: nymex | 2021-07-13 07:48:43.959 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-07-13 07:48:43.959 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-07-13 07:48:43.959 Triggering next historical data download in queue. | 2021-07-13 07:48:43.959 HD Request # 1 | Requesting historical Daily data for E6U21 starting at 2021-07-07. SC External HD service. | 2021-07-13 07:48:44.132 Mapping ESU21-CME to ESU21. Service code: cme | 2021-07-13 07:48:44.187 Added historical Intraday data request for ESU21-CME to the queue. | 2021-07-13 07:48:44.187 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-07-13 07:48:44.187 Triggering next historical data download in queue. | 2021-07-13 07:48:44.187 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:44.205 HD Request # 2 | Sending historical data logon request message. | 2021-07-13 07:48:44.205 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-07-12 19:38:46. Record interval: 0. Symbol: 6EU21 | 2021-07-13 07:48:44.779 HD Request # 2 | Decompressing data. | 2021-07-13 07:48:44.901 HD Request # 1 | Receiving historical Daily data for E6U21 starting at 2021-07-08 | 2021-07-13 07:48:44.921 HD Request # 1 | Writing historical Daily data to the file E6U21.dly | 2021-07-13 07:48:44.921 HD Request # 1 | Bytes received: 289 | 2021-07-13 07:48:44.934 HD Request # 1 | Received 5 records from 2021-07-08 00:00:00 to 2021-07-13 00:00:00 (6.0 days) and wrote 4 records for E6U21 | 2021-07-13 07:48:44.934 HD Request # 1 | Completion time: 1s | 2021-07-13 07:48:44.934 HD Request # 1 | Daily data download complete for E6U21. Unique request ID: 1 | 2021-07-13 07:48:44.934 Removing historical data download ID 1. | 2021-07-13 07:48:44.934 Triggering next historical data download in queue. | 2021-07-13 07:48:44.934 Mapping B6U21 to 6BU21. Service code: cme | 2021-07-13 07:48:44.934 HD Request # 3 | Downloading Historical Daily chart data for B6U21. Starting date: 2021-07-08. Service: scdataallservices | 2021-07-13 07:48:44.936 HD Request # 2 | Receiving Intraday data for 6EU21-CME starting at 2021-07-12 19:38:46.745000 | 2021-07-13 07:48:45.156 HD Request # 3 | Requesting historical Daily data for B6U21 starting at 2021-07-07. SC External HD service. | 2021-07-13 07:48:45.192 6EU21-CME [CB] 15 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:45.319 6EU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:45.320 Socket (2) | CloseSocket call. | 2021-07-13 07:48:45.322 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:45.322 HD Request # 2 | Historical data for 6EU21-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-07-13 07:48:45.368 Historical data download thread signaled to stop. | 2021-07-13 07:48:45.368 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-07-12 19:39:16.666000 | 2021-07-13 07:48:45.369 HD Request # 2 | Received 12625 records from 2021-07-12 19:38:46.745000 to 2021-07-13 07:38:04.185000 (12.0 hours) and wrote 12624 records for 6EU21-CME | 2021-07-13 07:48:45.369 HD Request # 2 | Completion time: 2s | 2021-07-13 07:48:45.369 HD Request # 2 | Intraday data download complete for 6EU21-CME. Unique request ID: 6 | 2021-07-13 07:48:45.369 Removing historical data download ID 6. | 2021-07-13 07:48:45.369 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:45.369 Triggering next historical data download in queue. | 2021-07-13 07:48:45.369 HD Request # 4 | Downloading Intraday chart data for 6BU21-CME to the file 6BU21-CME.scid. Service: cme | 2021-07-13 07:48:45.369 HD Request # 4 | Download start date-time: 2021-07-12 19:38:26.000000. File last date-time: 2021-07-12 19:38:26.036000 | 2021-07-13 07:48:45.370 HD Request # 4 | Using server: ds23.sierracharts.com port 10150 | 2021-07-13 07:48:45.403 6EU21-CME [CB] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:45.403 Socket (3) | Creating socket. | 2021-07-13 07:48:45.404 Socket (3) | New receive buffer size: 5242880 | 2021-07-13 07:48:45.404 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-07-13 07:48:45.404 6EU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:45.404 6EU21-CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:45.409 6EU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:45.424 Socket (2) | Socket gracefully closed by remote side. | 2021-07-13 07:48:45.445 Socket (2) | Closed. | 2021-07-13 07:48:45.445 6EU21-CME [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:45.506 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:45.661 HD Request # 4 | Sending historical data logon request message. | 2021-07-13 07:48:45.661 HD Request # 3 | Receiving historical Daily data for B6U21 starting at 2021-07-08 | 2021-07-13 07:48:45.667 HD Request # 3 | Writing historical Daily data to the file B6U21.dly | 2021-07-13 07:48:45.668 HD Request # 3 | Bytes received: 279 | 2021-07-13 07:48:45.683 HD Request # 3 | Received 5 records from 2021-07-08 00:00:00 to 2021-07-13 00:00:00 (6.0 days) and wrote 4 records for B6U21 | 2021-07-13 07:48:45.683 HD Request # 3 | Completion time: 1s | 2021-07-13 07:48:45.683 HD Request # 3 | Daily data download complete for B6U21. Unique request ID: 2 | 2021-07-13 07:48:45.683 Removing historical data download ID 2. | 2021-07-13 07:48:45.683 Triggering next historical data download in queue. | 2021-07-13 07:48:45.684 Mapping GCQ21 to GCQ21. Service code: comex | 2021-07-13 07:48:45.684 HD Request # 5 | Downloading Historical Daily chart data for GCQ21. Starting date: 2021-07-08. Service: scdataallservices | 2021-07-13 07:48:45.687 6EU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:45.836 HD Request # 5 | Requesting historical Daily data for GCQ21 starting at 2021-07-07. SC External HD service. | 2021-07-13 07:48:45.975 SC Data - All Services | Connected to server complete. | 2021-07-13 07:48:45.976 Triggering next historical data download in queue. | 2021-07-13 07:48:45.979 Triggering next historical data download in queue. | 2021-07-13 07:48:45.979 Triggering next historical data download in queue. | 2021-07-13 07:48:45.979 Triggering next historical data download in queue. | 2021-07-13 07:48:45.979 No download requests in the queue to start downloads for. | 2021-07-13 07:48:45.982 No download requests in the queue to start downloads for. | 2021-07-13 07:48:45.982 Mapping 6EU21-CME to 6EU21. Service code: cme | 2021-07-13 07:48:45.994 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6EU21-CME (6EU21). ID: 1 Service code: cme | 2021-07-13 07:48:45.994 SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2021-07-13 07:48:45.995 SC DTC Delayed Exchange Data | Requesting security definition data for: 6EU21-CME (6EU21). ID: 1 | 2021-07-13 07:48:45.995 Added historical Intraday data request for 6EU21-CME to the queue. | 2021-07-13 07:48:45.995 Intraday data recording state for symbol 6EU21-CME is set to download 'Pending'. | 2021-07-13 07:48:45.995 Triggering next historical data download in queue. | 2021-07-13 07:48:45.995 DTC Client socket (5) | Creating socket. | 2021-07-13 07:48:45.995 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-07-13 07:48:45.995 DTC Client socket (5) | Connecting to IP: 216.1.90.129. | 2021-07-13 07:48:45.995 6EU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:45.996 6EU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:46.010 6EU21-CME [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:46.120 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-07-13 07:48:46.125 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-07-13 07:48:46.125 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-07-13 07:48:46.125 Mapping CLQ21-NYMEX to CLQ21. Service code: nymex | 2021-07-13 07:48:46.126 Mapping CLU21-NYMEX to CLU21. Service code: nymex | 2021-07-13 07:48:46.126 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLU21-NYMEX (CLU21). ID: 3 Service code: nymex | 2021-07-13 07:48:46.126 SC DTC Delayed Exchange Data | Requesting security definition data for: CLU21-NYMEX (CLU21). ID: 3 | 2021-07-13 07:48:46.126 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLQ21-NYMEX (CLQ21). ID: 2 Service code: nymex | 2021-07-13 07:48:46.126 SC DTC Delayed Exchange Data | Requesting security definition data for: CLQ21-NYMEX (CLQ21). ID: 2 | 2021-07-13 07:48:46.126 6BU21-CME [CB] 15 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:46.126 6BU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:46.127 6BU21-CME [CB] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:46.177 6BU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:46.177 Mapping 6BU21-CME to 6BU21. Service code: cme | 2021-07-13 07:48:46.218 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6BU21-CME (6BU21). ID: 4 Service code: cme | 2021-07-13 07:48:46.218 SC DTC Delayed Exchange Data | Requesting security definition data for: 6BU21-CME (6BU21). ID: 4 | 2021-07-13 07:48:46.218 6BU21-CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:46.233 6BU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:46.233 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-07-12 19:38:26. Record interval: 0. Symbol: 6BU21 | 2021-07-13 07:48:46.251 6BU21-CME [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:46.319 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:46.320 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-07-13 07:48:46.320 Mapping ESU21-CME to ESU21. Service code: cme | 2021-07-13 07:48:46.328 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESU21-CME (ESU21). ID: 5 Service code: cme | 2021-07-13 07:48:46.328 SC DTC Delayed Exchange Data | Requesting security definition data for: ESU21-CME (ESU21). ID: 5 | 2021-07-13 07:48:46.328 Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-07-13 07:48:46.362 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCQ21-COMEX (GCQ21). ID: 6 Service code: comex | 2021-07-13 07:48:46.362 SC DTC Delayed Exchange Data | Requesting security definition data for: GCQ21-COMEX (GCQ21). ID: 6 | 2021-07-13 07:48:46.362 HD Request # 4 | Decompressing data. | 2021-07-13 07:48:46.374 HD Request # 5 | Receiving historical Daily data for GCQ21 starting at 2021-07-08 | 2021-07-13 07:48:46.495 HD Request # 5 | Writing historical Daily data to the file GCQ21.dly | 2021-07-13 07:48:46.496 HD Request # 5 | Bytes received: 280 | 2021-07-13 07:48:46.501 HD Request # 5 | Received 5 records from 2021-07-08 00:00:00 to 2021-07-13 00:00:00 (6.0 days) and wrote 4 records for GCQ21 | 2021-07-13 07:48:46.501 HD Request # 5 | Completion time: 1s | 2021-07-13 07:48:46.501 HD Request # 5 | Daily data download complete for GCQ21. Unique request ID: 3 | 2021-07-13 07:48:46.501 Removing historical data download ID 3. | 2021-07-13 07:48:46.501 Triggering next historical data download in queue. | 2021-07-13 07:48:46.502 Mapping CLQ21 to CLQ21. Service code: nymex | 2021-07-13 07:48:46.502 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLQ21 (CLQ21). ID: 7 Service code: nymex | 2021-07-13 07:48:46.502 SC DTC Delayed Exchange Data | Requesting security definition data for: CLQ21 (CLQ21). ID: 7 | 2021-07-13 07:48:46.502 HD Request # 6 | Downloading Historical Daily chart data for CLQ21. Starting date: 2021-07-08. Service: scdataallservices | 2021-07-13 07:48:46.505 6BU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:46.620 GCQ21-COMEX [CB] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:46.696 GCQ21-COMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:46.698 HD Request # 4 | Receiving Intraday data for 6BU21-CME starting at 2021-07-12 19:38:26.036000 | 2021-07-13 07:48:46.753 6BU21-CME [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:46.794 Socket (3) | CloseSocket call. | 2021-07-13 07:48:46.800 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:46.800 HD Request # 6 | Requesting historical Daily data for CLQ21 starting at 2021-07-07. SC External HD service. | 2021-07-13 07:48:46.806 HD Request # 4 | Re-requesting historical data for 6BU21-CME to get the latest data since the download was started while not connected to primary service. | 2021-07-13 07:48:46.808 Added historical Intraday data request for 6BU21-CME to the queue. | 2021-07-13 07:48:46.808 Intraday data recording state for symbol 6BU21-CME is set to download 'Pending'. | 2021-07-13 07:48:46.808 Triggering next historical data download in queue. | 2021-07-13 07:48:46.808 Historical data download thread signaled to stop. | 2021-07-13 07:48:46.808 HD Request # 4 | Timestamp of first Intraday data file record written: 2021-07-12 19:39:01.104000 | 2021-07-13 07:48:46.808 HD Request # 4 | Received 7351 records from 2021-07-12 19:38:26.036000 to 2021-07-13 07:36:46.355001 (12.0 hours) and wrote 7350 records for 6BU21-CME | 2021-07-13 07:48:46.808 HD Request # 4 | Completion time: 1s | 2021-07-13 07:48:46.808 Delaying start of download for 6BU21-CME | 2021-07-13 07:48:46.808 GCQ21-COMEX [CB] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:46.809 GCQ21-COMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:46.809 6BU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:46.812 Socket (3) | Socket gracefully closed by remote side. | 2021-07-13 07:48:46.922 Socket (3) | Closed. | 2021-07-13 07:48:46.922 6BU21-CME [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:47.001 GCQ21-COMEX [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:47.038 SC DTC Delayed Exchange Data | Received logon response. | 2021-07-13 07:48:47.046 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-07-13 07:48:47.046 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-07-13 07:48:47.046 SC DTC Delayed Exchange Data | Successfully connected. | 2021-07-13 07:48:47.046 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-07-13 07:48:47.046 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6BU21-CME -> 6BU21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6EU21-CME -> 6EU21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLQ21 -> CLQ21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLQ21-NYMEX -> CLQ21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLU21-NYMEX -> CLU21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESU21-CME -> ESU21 | 2021-07-13 07:48:47.047 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCQ21-COMEX -> GCQ21 | 2021-07-13 07:48:47.047 GCQ21-COMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:47.069 GCQ21-COMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:47.070 GCQ21-COMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:47.206 SC DTC Delayed Exchange Data | Received security definition for symbol 6BU21-CME | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol 6EU21-CME | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol CLQ21 | 2021-07-13 07:48:47.297 Symbol Error - CLQ21-NYMEX is unknown, unavailable, or improperly formatted. Already subscribed to symbol. New subscription rejected. | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol CLQ21-NYMEX | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol CLU21-NYMEX | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol ESU21-CME | 2021-07-13 07:48:47.297 SC DTC Delayed Exchange Data | Received security definition for symbol GCQ21-COMEX | 2021-07-13 07:48:47.297 GCQ21-COMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:47.306 GCQ21-COMEX [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:47.350 HD Request # 6 | Receiving historical Daily data for CLQ21 starting at 2021-07-08 | 2021-07-13 07:48:47.440 HD Request # 6 | Writing historical Daily data to the file CLQ21.dly | 2021-07-13 07:48:47.440 HD Request # 6 | Bytes received: 266 | 2021-07-13 07:48:47.455 HD Request # 6 | Received 5 records from 2021-07-08 00:00:00 to 2021-07-13 00:00:00 (6.0 days) and wrote 4 records for CLQ21 | 2021-07-13 07:48:47.455 HD Request # 6 | Completion time: 1s | 2021-07-13 07:48:47.455 HD Request # 6 | Daily data download complete for CLQ21. Unique request ID: 4 | 2021-07-13 07:48:47.455 Removing historical data download ID 4. | 2021-07-13 07:48:47.455 Triggering next historical data download in queue. | 2021-07-13 07:48:47.455 Mapping ESU21 to ESU21. Service code: cme | 2021-07-13 07:48:47.455 HD Request # 7 | Downloading Historical Daily chart data for ESU21. Starting date: 2021-07-08. Service: scdataallservices | 2021-07-13 07:48:47.458 CLQ21-NYMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:47.485 CLQ21-NYMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:47.486 GCQ21-COMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:47.681 CLQ21-NYMEX [CB] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:47.869 CLQ21-NYMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:47.869 HD Request # 7 | Requesting historical Daily data for ESU21 starting at 2021-07-07. SC External HD service. | 2021-07-13 07:48:48.077 CLQ21-NYMEX [CB] 5 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:48.110 CLQ21-NYMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:48.122 Created process C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_2 | 2021-07-13 07:48:49.091 Created process C:\SierraChart\SierraChartInstance_3\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_3 | 2021-07-13 07:48:49.752 CLQ21-NYMEX [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:49.753 HD Request # 7 | Receiving historical Daily data for ESU21 starting at 2021-07-08 | 2021-07-13 07:48:49.754 HD Request # 7 | Writing historical Daily data to the file ESU21.dly | 2021-07-13 07:48:49.754 HD Request # 7 | Bytes received: 294 | 2021-07-13 07:48:49.758 HD Request # 7 | Received 5 records from 2021-07-08 00:00:00 to 2021-07-13 00:00:00 (6.0 days) and wrote 4 records for ESU21 | 2021-07-13 07:48:49.758 HD Request # 7 | Completion time: 2s | 2021-07-13 07:48:49.758 HD Request # 7 | Daily data download complete for ESU21. Unique request ID: 5 | 2021-07-13 07:48:49.758 Removing historical data download ID 5. | 2021-07-13 07:48:49.758 Triggering next historical data download in queue. | 2021-07-13 07:48:49.758 No download requests in the queue to start downloads for. | 2021-07-13 07:48:49.770 CLQ21-NYMEX [CBV] #3 | Reloading chart. | 2021-07-13 07:48:49.771 ESU21-CME [CB] 15 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:50.022 ESU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:50.023 ESU21-CME [CB] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:50.078 ESU21-CME [CB] 1 Min #2 | Reloading chart. | 2021-07-13 07:48:50.078 ESU21-CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-07-13 07:48:50.190 ESU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:50.199 CLQ21-NYMEX [CB] 15 Min #1 | Reloading chart. | 2021-07-13 07:48:50.290 ESU21-CME [CB] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:50.641 CLQ21-NYMEX [CB] 5 Min #2 | Reloading chart. | 2021-07-13 07:48:50.675 ESU21-CME [CB] 15 Min #4 | Reloading chart. | 2021-07-13 07:48:50.853 CLQ21-NYMEX [CB] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:50.926 ESU21-CME [CB] 1 Min #2 | Reloading chart. | 2021-07-13 07:48:50.955 ESU21-CME [CBV] #3 | Reloading chart. | 2021-07-13 07:48:50.977 ESU21-CME [CB] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-07-13 07:48:51.272 HD Request # 8 | Downloading Intraday chart data for 6BU21-CME to the file 6BU21-CME.scid. Service: cme | 2021-07-13 07:48:52.951 HD Request # 8 | Download start date-time: 2021-07-13 07:36:46.000000. File last date-time: 2021-07-13 07:36:46.355001 | 2021-07-13 07:48:52.952 HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2021-07-13 07:48:52.952 Socket (1) | Creating socket. | 2021-07-13 07:48:52.952 Socket (1) | New receive buffer size: 5242880 | 2021-07-13 07:48:52.952 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-07-13 07:48:52.952 HD Request # 8 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:53.201 HD Request # 8 | Sending historical data logon request message. | 2021-07-13 07:48:53.201 HD Request # 8 | Requesting Intraday data. Start date-time: 2021-07-13 07:36:46. Record interval: 0. Symbol: 6BU21 | 2021-07-13 07:48:53.322 HD Request # 8 | Decompressing data. | 2021-07-13 07:48:53.443 HD Request # 8 | Receiving Intraday data for 6BU21-CME starting at 2021-07-13 07:36:46.159000 | 2021-07-13 07:48:53.445 Socket (1) | CloseSocket call. | 2021-07-13 07:48:53.445 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:53.445 Historical data download thread signaled to stop. | 2021-07-13 07:48:53.445 HD Request # 8 | Received 3 records from 2021-07-13 07:36:46.159000 to 2021-07-13 07:36:46.355001 (0.2 seconds) and wrote 0 records for 6BU21-CME | 2021-07-13 07:48:53.445 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2021-07-13 05:36:46.355001 | 2021-07-13 07:48:53.446 HD Request # 8 | Completion time: 1s | 2021-07-13 07:48:53.446 HD Request # 8 | Intraday data download complete for 6BU21-CME. Unique request ID: 7 | 2021-07-13 07:48:53.446 Removing historical data download ID 7. | 2021-07-13 07:48:53.446 Real-time Intraday chart data file updates started for 6BU21-CME | 2021-07-13 07:48:53.446 Intraday chart data file opened for 6BU21-CME | 2021-07-13 07:48:53.446 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:53.446 Triggering next historical data download in queue. | 2021-07-13 07:48:53.446 HD Request # 9 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-07-13 07:48:53.446 HD Request # 9 | Download start date-time: 2021-07-12 19:38:53.000000. File last date-time: 2021-07-12 19:38:53.043000 | 2021-07-13 07:48:53.446 HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2021-07-13 07:48:53.446 Socket (2) | Creating socket. | 2021-07-13 07:48:53.446 Socket (2) | New receive buffer size: 5242880 | 2021-07-13 07:48:53.446 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-07-13 07:48:53.446 Socket (1) | Socket gracefully closed by remote side. | 2021-07-13 07:48:53.565 Socket (1) | Closed. | 2021-07-13 07:48:53.566 HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:53.700 HD Request # 9 | Sending historical data logon request message. | 2021-07-13 07:48:53.700 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-07-12 19:38:53. Record interval: 0. Symbol: GCQ21 | 2021-07-13 07:48:53.822 HD Request # 9 | Decompressing data. | 2021-07-13 07:48:53.944 HD Request # 9 | Receiving Intraday data for GCQ21-COMEX starting at 2021-07-12 19:38:53.043000 | 2021-07-13 07:48:54.207 Socket (2) | CloseSocket call. | 2021-07-13 07:48:54.590 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:54.591 Historical data download thread signaled to stop. | 2021-07-13 07:48:54.618 HD Request # 9 | Timestamp of first Intraday data file record written: 2021-07-12 19:39:01.168000 | 2021-07-13 07:48:54.619 HD Request # 9 | Received 25270 records from 2021-07-12 19:38:53.043000 to 2021-07-13 07:38:47.692000 (12.0 hours) and wrote 25269 records for GCQ21-COMEX | 2021-07-13 07:48:54.619 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-07-13 05:38:47.692000 | 2021-07-13 07:48:54.620 HD Request # 9 | Completion time: 1s | 2021-07-13 07:48:54.620 HD Request # 9 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 8 | 2021-07-13 07:48:54.620 Removing historical data download ID 8. | 2021-07-13 07:48:54.620 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-07-13 07:48:54.620 Intraday chart data file opened for GCQ21-COMEX | 2021-07-13 07:48:54.620 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:54.620 Triggering next historical data download in queue. | 2021-07-13 07:48:54.620 HD Request # 10 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-07-13 07:48:54.620 HD Request # 10 | Download start date-time: 2021-07-12 18:37:09.000000. File last date-time: 2021-07-12 18:37:09.652000 | 2021-07-13 07:48:54.620 HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2021-07-13 07:48:54.620 Socket (1) | Creating socket. | 2021-07-13 07:48:54.620 Socket (1) | New receive buffer size: 5242880 | 2021-07-13 07:48:54.620 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-07-13 07:48:54.620 Socket (2) | Socket gracefully closed by remote side. | 2021-07-13 07:48:54.713 Socket (2) | Closed. | 2021-07-13 07:48:54.713 HD Request # 10 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:54.892 HD Request # 10 | Sending historical data logon request message. | 2021-07-13 07:48:54.892 HD Request # 10 | Requesting Intraday data. Start date-time: 2021-07-12 18:37:09. Record interval: 0. Symbol: CLQ21 | 2021-07-13 07:48:55.016 HD Request # 10 | Decompressing data. | 2021-07-13 07:48:55.139 HD Request # 10 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-07-12 18:37:09.504000 | 2021-07-13 07:48:55.398 HD Request # 10 | Timestamp of first Intraday data file record written: 2021-07-12 18:37:21.830000 | 2021-07-13 07:48:55.898 Socket (1) | CloseSocket call. | 2021-07-13 07:48:55.912 Historical data download thread signaled to stop. | 2021-07-13 07:48:55.912 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:55.912 HD Request # 10 | Received 46299 records from 2021-07-12 18:37:09.504000 to 2021-07-13 07:38:51.266005 (13.0 hours) and wrote 46294 records for CLQ21-NYMEX | 2021-07-13 07:48:55.913 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2021-07-13 05:38:51.266005 | 2021-07-13 07:48:55.915 HD Request # 10 | Completion time: 1s | 2021-07-13 07:48:55.915 HD Request # 10 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 9 | 2021-07-13 07:48:55.915 Removing historical data download ID 9. | 2021-07-13 07:48:55.915 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-07-13 07:48:55.915 Intraday chart data file opened for CLQ21-NYMEX | 2021-07-13 07:48:55.915 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:55.915 Triggering next historical data download in queue. | 2021-07-13 07:48:55.915 HD Request # 11 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-07-13 07:48:55.920 HD Request # 11 | Download start date-time: 2021-07-12 19:39:00.000000. File last date-time: 2021-07-12 19:39:00.016000 | 2021-07-13 07:48:55.921 HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2021-07-13 07:48:55.921 Socket (2) | Creating socket. | 2021-07-13 07:48:55.921 Socket (2) | New receive buffer size: 5242880 | 2021-07-13 07:48:55.921 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-07-13 07:48:55.921 Socket (1) | Socket gracefully closed by remote side. | 2021-07-13 07:48:56.033 Socket (1) | Closed. | 2021-07-13 07:48:56.033 HD Request # 11 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:56.176 HD Request # 11 | Sending historical data logon request message. | 2021-07-13 07:48:56.176 HD Request # 11 | Requesting Intraday data. Start date-time: 2021-07-12 19:39:00. Record interval: 0. Symbol: ESU21 | 2021-07-13 07:48:56.302 HD Request # 11 | Decompressing data. | 2021-07-13 07:48:56.425 HD Request # 11 | Receiving Intraday data for ESU21-CME starting at 2021-07-12 19:39:00.015000 | 2021-07-13 07:48:56.686 HD Request # 11 | Timestamp of first Intraday data file record written: 2021-07-12 19:39:02.401000 | 2021-07-13 07:48:57.570 Socket (2) | CloseSocket call. | 2021-07-13 07:48:58.247 Historical data download thread signaled to stop. | 2021-07-13 07:48:58.247 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:58.248 HD Request # 11 | Received 151733 records from 2021-07-12 19:39:00.015000 to 2021-07-13 07:38:45.005001 (12.0 hours) and wrote 151730 records for ESU21-CME | 2021-07-13 07:48:58.248 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2021-07-13 05:38:45.005001 | 2021-07-13 07:48:58.249 HD Request # 11 | Completion time: 3s | 2021-07-13 07:48:58.249 HD Request # 11 | Intraday data download complete for ESU21-CME. Unique request ID: 10 | 2021-07-13 07:48:58.249 Removing historical data download ID 10. | 2021-07-13 07:48:58.249 Real-time Intraday chart data file updates started for ESU21-CME | 2021-07-13 07:48:58.249 Intraday chart data file opened for ESU21-CME | 2021-07-13 07:48:58.249 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:58.249 Triggering next historical data download in queue. | 2021-07-13 07:48:58.249 HD Request # 12 | Downloading Intraday chart data for 6EU21-CME to the file 6EU21-CME.scid. Service: cme | 2021-07-13 07:48:58.249 HD Request # 12 | Download start date-time: 2021-07-13 07:38:04.000000. File last date-time: 2021-07-13 07:38:04.185000 | 2021-07-13 07:48:58.249 HD Request # 12 | Using server: ds21.sierracharts.com port 10149 | 2021-07-13 07:48:58.250 Socket (1) | Creating socket. | 2021-07-13 07:48:58.250 Socket (1) | New receive buffer size: 5242880 | 2021-07-13 07:48:58.250 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-07-13 07:48:58.250 Socket (2) | Socket gracefully closed by remote side. | 2021-07-13 07:48:58.370 Socket (2) | Closed. | 2021-07-13 07:48:58.370 HD Request # 12 | Setting DTC encoding to Binary VLS | 2021-07-13 07:48:58.497 HD Request # 12 | Sending historical data logon request message. | 2021-07-13 07:48:58.498 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 4424 | 2021-07-13 07:48:58.507 HD Request # 12 | Requesting Intraday data. Start date-time: 2021-07-13 07:38:04. Record interval: 0. Symbol: 6EU21 | 2021-07-13 07:48:58.619 HD Request # 12 | Decompressing data. | 2021-07-13 07:48:58.740 HD Request # 12 | Receiving Intraday data for 6EU21-CME starting at 2021-07-13 07:38:04.185000 | 2021-07-13 07:48:58.742 Socket (1) | CloseSocket call. | 2021-07-13 07:48:58.742 Historical data download thread signaled to stop. | 2021-07-13 07:48:58.742 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-07-13 07:48:58.742 HD Request # 12 | Timestamp of first Intraday data file record written: 2021-07-13 07:38:49.824000 | 2021-07-13 07:48:58.742 HD Request # 12 | Received 5 records from 2021-07-13 07:38:04.185000 to 2021-07-13 07:38:54.871002 (50.7 seconds) and wrote 4 records for 6EU21-CME | 2021-07-13 07:48:58.742 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2021-07-13 05:38:54.871002 | 2021-07-13 07:48:58.743 HD Request # 12 | Completion time: 0s | 2021-07-13 07:48:58.743 HD Request # 12 | Intraday data download complete for 6EU21-CME. Unique request ID: 11 | 2021-07-13 07:48:58.743 Removing historical data download ID 11. | 2021-07-13 07:48:58.743 Real-time Intraday chart data file updates started for 6EU21-CME | 2021-07-13 07:48:58.743 Intraday chart data file opened for 6EU21-CME | 2021-07-13 07:48:58.743 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2021-07-13 07:48:58.743 Triggering next historical data download in queue. | 2021-07-13 07:48:58.743 No download requests in the queue to start downloads for. | 2021-07-13 07:48:58.743 Socket (1) | Socket gracefully closed by remote side. | 2021-07-13 07:48:58.865 Socket (1) | Closed. | 2021-07-13 07:48:58.865 Opened cached Intraday file: C:\SierraChart\Data\6EU21-CME.scid. Thread ID: 4424 | 2021-07-13 07:49:00.558 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.084 HD Server Manager | Started new historical data server. Count=1 | 2021-07-13 07:49:01.085 HD Server | Thread:19720 (1) | Creating socket. | 2021-07-13 07:49:01.108 HD Server | Thread:19720 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.108 HD Server | Thread:19720 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.108 HD Server | Setting DTC encoding to Binary VLS | Thread:19720 | 2021-07-13 07:49:01.108 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:19720 | 2021-07-13 07:49:01.114 HD Server | Login has been authorized. | Username: Rollmops. | Thread:19720 | 2021-07-13 07:49:01.114 HD Server | HD Request #1 | Socket: 1 | Symbol: E6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 1 | Username: Rollmops. | Thread:19720 | 2021-07-13 07:49:01.117 HD Server | HD Request | Socket: 1 | Symbol: E6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 1 | Username: Rollmops. | Thread:19720 | 2021-07-13 07:49:01.147 HD Server | Thread:19720 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.182 HD Server | Thread:19720 (1) | CloseSocket call. | 2021-07-13 07:49:01.182 HD Server | Thread:19720 (0) | CloseSocket call. | 2021-07-13 07:49:01.184 HD Server | Thread:19720 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.184 HD Server | Thread:19720 (1) | Closed. | 2021-07-13 07:49:01.184 HD Server | Thread:19720 (0) | CloseSocket call. | 2021-07-13 07:49:01.184 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.190 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:01.191 HD Server | Thread:17256 (1) | Creating socket. | 2021-07-13 07:49:01.210 HD Server | Thread:17256 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.210 HD Server | Thread:17256 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.210 HD Server | Setting DTC encoding to Binary VLS | Thread:17256 | 2021-07-13 07:49:01.210 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:17256 | 2021-07-13 07:49:01.213 HD Server | Login has been authorized. | Username: Rollmops. | Thread:17256 | 2021-07-13 07:49:01.213 HD Server | HD Request #2 | Socket: 1 | Symbol: B6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 2 | Username: Rollmops. | Thread:17256 | 2021-07-13 07:49:01.215 HD Server | HD Request | Socket: 1 | Symbol: B6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 2 | Username: Rollmops. | Thread:17256 | 2021-07-13 07:49:01.247 HD Server | Thread:17256 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.274 HD Server | Thread:17256 (1) | CloseSocket call. | 2021-07-13 07:49:01.274 HD Server | Thread:17256 (0) | CloseSocket call. | 2021-07-13 07:49:01.275 HD Server | Thread:17256 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.275 HD Server | Thread:17256 (1) | Closed. | 2021-07-13 07:49:01.275 HD Server | Thread:17256 (0) | CloseSocket call. | 2021-07-13 07:49:01.275 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.309 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:01.310 HD Server | Thread:2892 (1) | Creating socket. | 2021-07-13 07:49:01.327 HD Server | Thread:2892 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.327 HD Server | Thread:2892 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.327 HD Server | Setting DTC encoding to Binary VLS | Thread:2892 | 2021-07-13 07:49:01.327 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:2892 | 2021-07-13 07:49:01.329 HD Server | Login has been authorized. | Username: Rollmops. | Thread:2892 | 2021-07-13 07:49:01.329 HD Server | HD Request #3 | Socket: 1 | Symbol: GCQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 3 | Username: Rollmops. | Thread:2892 | 2021-07-13 07:49:01.330 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:17256 | 2021-07-13 07:49:01.334 HD Server Manager | Current server count=2 | 2021-07-13 07:49:01.335 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:19720 | 2021-07-13 07:49:01.335 HD Server Manager | Current server count=1 | 2021-07-13 07:49:01.335 HD Server | HD Request | Socket: 1 | Symbol: GCQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 3 | Username: Rollmops. | Thread:2892 | 2021-07-13 07:49:01.341 HD Server | Thread:2892 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.357 HD Server | Thread:2892 (1) | CloseSocket call. | 2021-07-13 07:49:01.357 HD Server | Thread:2892 (0) | CloseSocket call. | 2021-07-13 07:49:01.358 HD Server | Thread:2892 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.358 HD Server | Thread:2892 (1) | Closed. | 2021-07-13 07:49:01.358 HD Server | Thread:2892 (0) | CloseSocket call. | 2021-07-13 07:49:01.358 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.482 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:01.483 HD Server | Thread:14796 (1) | Creating socket. | 2021-07-13 07:49:01.504 HD Server | Thread:14796 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.504 HD Server | Thread:14796 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.504 HD Server | Setting DTC encoding to Binary VLS | Thread:14796 | 2021-07-13 07:49:01.504 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:14796 | 2021-07-13 07:49:01.509 HD Server | Login has been authorized. | Username: Rollmops. | Thread:14796 | 2021-07-13 07:49:01.509 HD Server | HD Request #4 | Socket: 1 | Symbol: CLQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 4 | Username: Rollmops. | Thread:14796 | 2021-07-13 07:49:01.514 HD Server | HD Request | Socket: 1 | Symbol: CLQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 4 | Username: Rollmops. | Thread:14796 | 2021-07-13 07:49:01.549 HD Server | Thread:14796 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.585 HD Server | Thread:14796 (1) | CloseSocket call. | 2021-07-13 07:49:01.585 HD Server | Thread:14796 (0) | CloseSocket call. | 2021-07-13 07:49:01.586 HD Server | Thread:14796 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.587 HD Server | Thread:14796 (1) | Closed. | 2021-07-13 07:49:01.587 HD Server | Thread:14796 (0) | CloseSocket call. | 2021-07-13 07:49:01.587 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.601 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:01.602 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:14796 | 2021-07-13 07:49:01.602 HD Server Manager | Current server count=2 | 2021-07-13 07:49:01.613 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:2892 | 2021-07-13 07:49:01.614 HD Server Manager | Current server count=1 | 2021-07-13 07:49:01.615 HD Server | Thread:8348 (1) | Creating socket. | 2021-07-13 07:49:01.617 HD Server | Thread:8348 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.617 HD Server | Thread:8348 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.617 HD Server | Setting DTC encoding to Binary VLS | Thread:8348 | 2021-07-13 07:49:01.617 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:8348 | 2021-07-13 07:49:01.619 HD Server | Login has been authorized. | Username: Rollmops. | Thread:8348 | 2021-07-13 07:49:01.619 HD Server | HD Request #1 | Socket: 1 | Symbol: E6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 1 | Username: Rollmops. | Thread:8348 | 2021-07-13 07:49:01.621 HD Server | HD Request | Socket: 1 | Symbol: E6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 1 | Username: Rollmops. | Thread:8348 | 2021-07-13 07:49:01.649 HD Server | Thread:8348 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.680 HD Server | Thread:8348 (1) | CloseSocket call. | 2021-07-13 07:49:01.680 HD Server | Thread:8348 (0) | CloseSocket call. | 2021-07-13 07:49:01.681 HD Server | Thread:8348 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.681 HD Server | Thread:8348 (1) | Closed. | 2021-07-13 07:49:01.681 HD Server | Thread:8348 (0) | CloseSocket call. | 2021-07-13 07:49:01.681 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.688 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:01.691 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.698 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:01.699 HD Server | Thread:1036 (1) | Creating socket. | 2021-07-13 07:49:01.718 HD Server | Thread:1036 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.718 HD Server | Thread:1036 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.718 HD Server | Setting DTC encoding to Binary VLS | Thread:1036 | 2021-07-13 07:49:01.718 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:1036 | 2021-07-13 07:49:01.721 HD Server | Login has been authorized. | Username: Rollmops. | Thread:1036 | 2021-07-13 07:49:01.721 HD Server | HD Request #2 | Socket: 1 | Symbol: B6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 2 | Username: Rollmops. | Thread:1036 | 2021-07-13 07:49:01.728 HD Server | Thread:13000 (2) | Creating socket. | 2021-07-13 07:49:01.728 HD Server | Thread:13000 (2) | New receive buffer size: 262144 | 2021-07-13 07:49:01.728 HD Server | Thread:13000 (2) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.729 HD Server | Setting DTC encoding to Binary VLS | Thread:13000 | 2021-07-13 07:49:01.729 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:13000 | 2021-07-13 07:49:01.731 HD Server | Login has been authorized. | Username: Rollmops. | Thread:13000 | 2021-07-13 07:49:01.731 HD Server | HD Request #5 | Socket: 2 | Symbol: ESU21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 5 | Username: Rollmops. | Thread:13000 | 2021-07-13 07:49:01.733 HD Server | HD Request | Socket: 2 | Symbol: ESU21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 5 | Username: Rollmops. | Thread:13000 | 2021-07-13 07:49:01.741 HD Server | Thread:13000 (2) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.750 HD Server | Thread:13000 (2) | CloseSocket call. | 2021-07-13 07:49:01.750 HD Server | Thread:13000 (0) | CloseSocket call. | 2021-07-13 07:49:01.752 HD Server | Thread:13000 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.752 HD Server | Thread:13000 (2) | Closed. | 2021-07-13 07:49:01.752 HD Server | Thread:13000 (0) | CloseSocket call. | 2021-07-13 07:49:01.752 HD Server | HD Request | Socket: 1 | Symbol: B6U21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 2 | Username: Rollmops. | Thread:1036 | 2021-07-13 07:49:01.759 HD Server | Thread:1036 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.800 HD Server | Thread:1036 (1) | CloseSocket call. | 2021-07-13 07:49:01.800 HD Server | Thread:1036 (0) | CloseSocket call. | 2021-07-13 07:49:01.800 HD Server | Thread:1036 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.801 HD Server | Thread:1036 (1) | Closed. | 2021-07-13 07:49:01.801 HD Server | Thread:1036 (0) | CloseSocket call. | 2021-07-13 07:49:01.801 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.830 HD Server Manager | Started new historical data server. Count=4 | 2021-07-13 07:49:01.831 HD Server | Thread:16232 (1) | Creating socket. | 2021-07-13 07:49:01.848 HD Server | Thread:16232 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.848 HD Server | Thread:16232 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.848 HD Server | Setting DTC encoding to Binary VLS | Thread:16232 | 2021-07-13 07:49:01.850 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:16232 | 2021-07-13 07:49:01.853 HD Server | Login has been authorized. | Username: Rollmops. | Thread:16232 | 2021-07-13 07:49:01.853 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:13000 | 2021-07-13 07:49:01.853 HD Server Manager | Current server count=3 | 2021-07-13 07:49:01.854 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:1036 | 2021-07-13 07:49:01.854 HD Server Manager | Current server count=2 | 2021-07-13 07:49:01.854 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:8348 | 2021-07-13 07:49:01.854 HD Server Manager | Current server count=1 | 2021-07-13 07:49:01.854 HD Server | HD Request #3 | Socket: 1 | Symbol: GCQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 3 | Username: Rollmops. | Thread:16232 | 2021-07-13 07:49:01.855 HD Server | HD Request | Socket: 1 | Symbol: GCQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 3 | Username: Rollmops. | Thread:16232 | 2021-07-13 07:49:01.867 HD Server | Thread:16232 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.882 HD Server | Thread:16232 (1) | CloseSocket call. | 2021-07-13 07:49:01.882 HD Server | Thread:16232 (0) | CloseSocket call. | 2021-07-13 07:49:01.883 HD Server | Thread:16232 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.883 HD Server | Thread:16232 (1) | Closed. | 2021-07-13 07:49:01.883 HD Server | Thread:16232 (0) | CloseSocket call. | 2021-07-13 07:49:01.883 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:01.904 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:01.905 HD Server | Thread:12264 (1) | Creating socket. | 2021-07-13 07:49:01.925 HD Server | Thread:12264 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:01.925 HD Server | Thread:12264 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:01.925 HD Server | Setting DTC encoding to Binary VLS | Thread:12264 | 2021-07-13 07:49:01.925 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:12264 | 2021-07-13 07:49:01.927 HD Server | Login has been authorized. | Username: Rollmops. | Thread:12264 | 2021-07-13 07:49:01.927 HD Server | HD Request #6 | Socket: 1 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:46 | ClientReqID: 6 | Username: Rollmops. | Thread:12264 | 2021-07-13 07:49:01.929 HD Server | HD Request | Socket: 1 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 12629 | ClientReqID: 6 | Username: Rollmops. | Thread:12264 | 2021-07-13 07:49:01.974 HD Server | Thread:12264 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:01.997 HD Server | Thread:12264 (1) | CloseSocket call. | 2021-07-13 07:49:01.997 HD Server | Thread:12264 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:01.998 HD Server | Thread:12264 (1) | Closed. | 2021-07-13 07:49:01.998 HD Server | Thread:12264 (0) | CloseSocket call. | 2021-07-13 07:49:01.998 HD Server | Thread:12264 (0) | CloseSocket call. | 2021-07-13 07:49:01.998 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.072 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:02.073 HD Server | Thread:16284 (1) | Creating socket. | 2021-07-13 07:49:02.094 HD Server | Thread:16284 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:02.094 HD Server | Thread:16284 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.094 HD Server | Setting DTC encoding to Binary VLS | Thread:16284 | 2021-07-13 07:49:02.094 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:16284 | 2021-07-13 07:49:02.096 HD Server | Login has been authorized. | Username: Rollmops. | Thread:16284 | 2021-07-13 07:49:02.096 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:12264 | 2021-07-13 07:49:02.096 HD Server Manager | Current server count=2 | 2021-07-13 07:49:02.097 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:16232 | 2021-07-13 07:49:02.097 HD Server Manager | Current server count=1 | 2021-07-13 07:49:02.097 HD Server | HD Request #4 | Socket: 1 | Symbol: ESU21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 4 | Username: Rollmops. | Thread:16284 | 2021-07-13 07:49:02.098 HD Server | HD Request | Socket: 1 | Symbol: ESU21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 4 | Username: Rollmops. | Thread:16284 | 2021-07-13 07:49:02.105 HD Server | Thread:16284 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.114 HD Server | Thread:16284 (1) | CloseSocket call. | 2021-07-13 07:49:02.114 HD Server | Thread:16284 (0) | CloseSocket call. | 2021-07-13 07:49:02.114 HD Server | Thread:16284 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.115 HD Server | Thread:16284 (1) | Closed. | 2021-07-13 07:49:02.115 HD Server | Thread:16284 (0) | CloseSocket call. | 2021-07-13 07:49:02.115 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.199 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:02.200 HD Server | Thread:14816 (1) | Creating socket. | 2021-07-13 07:49:02.215 HD Server | Thread:14816 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:02.215 HD Server | Thread:14816 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.215 HD Server | Setting DTC encoding to Binary VLS | Thread:14816 | 2021-07-13 07:49:02.215 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:14816 | 2021-07-13 07:49:02.217 HD Server | Login has been authorized. | Username: Rollmops. | Thread:14816 | 2021-07-13 07:49:02.217 HD Server | HD Request #7 | Socket: 1 | Symbol: 6BU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:26 | ClientReqID: 7 | Username: Rollmops. | Thread:14816 | 2021-07-13 07:49:02.219 HD Server | HD Request | Socket: 1 | Symbol: 6BU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 7351 | ClientReqID: 7 | Username: Rollmops. | Thread:14816 | 2021-07-13 07:49:02.253 HD Server | Thread:14816 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.275 HD Server | Thread:14816 (1) | CloseSocket call. | 2021-07-13 07:49:02.275 HD Server | Thread:14816 (0) | CloseSocket call. | 2021-07-13 07:49:02.276 HD Server | Thread:14816 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.276 HD Server | Thread:14816 (1) | Closed. | 2021-07-13 07:49:02.276 HD Server | Thread:14816 (0) | CloseSocket call. | 2021-07-13 07:49:02.276 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.332 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:02.333 HD Server | Thread:17836 (1) | Creating socket. | 2021-07-13 07:49:02.353 HD Server | Thread:17836 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:02.354 HD Server | Thread:17836 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.354 HD Server | Setting DTC encoding to Binary VLS | Thread:17836 | 2021-07-13 07:49:02.354 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:14816 | 2021-07-13 07:49:02.355 HD Server Manager | Current server count=2 | 2021-07-13 07:49:02.355 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:16284 | 2021-07-13 07:49:02.355 HD Server Manager | Current server count=1 | 2021-07-13 07:49:02.355 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:17836 | 2021-07-13 07:49:02.356 HD Server | Login has been authorized. | Username: Rollmops. | Thread:17836 | 2021-07-13 07:49:02.356 HD Server | HD Request #5 | Socket: 1 | Symbol: CLQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-07-08 00:00:00 | ClientReqID: 5 | Username: Rollmops. | Thread:17836 | 2021-07-13 07:49:02.358 HD Server | HD Request | Socket: 1 | Symbol: CLQ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 5 | Username: Rollmops. | Thread:17836 | 2021-07-13 07:49:02.407 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.422 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:02.423 HD Server | Thread:17536 (2) | Creating socket. | 2021-07-13 07:49:02.445 HD Server | Thread:17536 (2) | New receive buffer size: 262144 | 2021-07-13 07:49:02.445 HD Server | Thread:17536 (2) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.446 HD Server | Setting DTC encoding to Binary VLS | Thread:17536 | 2021-07-13 07:49:02.446 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:17536 | 2021-07-13 07:49:02.448 HD Server | Login has been authorized. | Username: Rollmops. | Thread:17536 | 2021-07-13 07:49:02.448 HD Server | HD Request #8 | Socket: 2 | Symbol: CLQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 16:42:41 | ClientReqID: 8 | Username: Rollmops. | Thread:17536 | 2021-07-13 07:49:02.450 HD Server | Thread:17836 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.458 HD Server | Thread:17836 (1) | CloseSocket call. | 2021-07-13 07:49:02.458 HD Server | Thread:17836 (0) | CloseSocket call. | 2021-07-13 07:49:02.459 HD Server | Thread:17836 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.459 HD Server | Thread:17836 (1) | Closed. | 2021-07-13 07:49:02.460 HD Server | Thread:17836 (0) | CloseSocket call. | 2021-07-13 07:49:02.460 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.521 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:02.522 HD Server | Thread:6764 (1) | Creating socket. | 2021-07-13 07:49:02.549 HD Server | Thread:6764 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:02.549 HD Server | Thread:6764 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.549 HD Server | Setting DTC encoding to Binary VLS | Thread:6764 | 2021-07-13 07:49:02.549 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:6764 | 2021-07-13 07:49:02.551 HD Server | Login has been authorized. | Username: Rollmops. | Thread:6764 | 2021-07-13 07:49:02.551 HD Server | HD Request #6 | Socket: 1 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:46 | ClientReqID: 6 | Username: Rollmops. | Thread:6764 | 2021-07-13 07:49:02.553 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:17836 | 2021-07-13 07:49:02.601 HD Server Manager | Current server count=2 | 2021-07-13 07:49:02.601 HD Server | HD Request | Socket: 1 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 12629 | ClientReqID: 6 | Username: Rollmops. | Thread:6764 | 2021-07-13 07:49:02.642 HD Server | Thread:6764 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.772 HD Server | Thread:6764 (1) | CloseSocket call. | 2021-07-13 07:49:02.772 HD Server | Thread:6764 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.773 HD Server | Thread:6764 (1) | Closed. | 2021-07-13 07:49:02.773 HD Server | Thread:6764 (0) | CloseSocket call. | 2021-07-13 07:49:02.773 HD Server | Thread:6764 (0) | CloseSocket call. | 2021-07-13 07:49:02.773 HD Server | HD Request | Socket: 2 | Symbol: CLQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 45549 | ClientReqID: 8 | Username: Rollmops. | Thread:17536 | 2021-07-13 07:49:02.783 HD Server | Thread:17536 (2) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.824 HD Server | Thread:17536 (2) | CloseSocket call. | 2021-07-13 07:49:02.825 HD Server | Thread:17536 (0) | CloseSocket call. | 2021-07-13 07:49:02.825 HD Server | Thread:17536 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.825 HD Server | Thread:17536 (2) | Closed. | 2021-07-13 07:49:02.825 HD Server | Thread:17536 (0) | CloseSocket call. | 2021-07-13 07:49:02.825 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:02.840 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:02.841 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:6764 | 2021-07-13 07:49:02.850 HD Server Manager | Current server count=2 | 2021-07-13 07:49:02.850 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:17536 | 2021-07-13 07:49:02.850 HD Server Manager | Current server count=1 | 2021-07-13 07:49:02.851 HD Server | Thread:2836 (1) | Creating socket. | 2021-07-13 07:49:02.899 HD Server | Thread:2836 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:02.899 HD Server | Thread:2836 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:02.900 HD Server | Setting DTC encoding to Binary VLS | Thread:2836 | 2021-07-13 07:49:02.900 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:2836 | 2021-07-13 07:49:02.902 HD Server | Login has been authorized. | Username: Rollmops. | Thread:2836 | 2021-07-13 07:49:02.902 HD Server | HD Request #7 | Socket: 1 | Symbol: 6BU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:26 | ClientReqID: 7 | Username: Rollmops. | Thread:2836 | 2021-07-13 07:49:02.904 HD Server | HD Request | Socket: 1 | Symbol: 6BU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 7351 | ClientReqID: 7 | Username: Rollmops. | Thread:2836 | 2021-07-13 07:49:02.962 HD Server | Thread:2836 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:02.980 HD Server | Thread:2836 (1) | CloseSocket call. | 2021-07-13 07:49:02.981 HD Server | Thread:2836 (0) | CloseSocket call. | 2021-07-13 07:49:02.981 HD Server | Thread:2836 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:02.981 HD Server | Thread:2836 (1) | Closed. | 2021-07-13 07:49:02.981 HD Server | Thread:2836 (0) | CloseSocket call. | 2021-07-13 07:49:02.981 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:03.099 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:03.100 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:2836 | 2021-07-13 07:49:03.101 HD Server Manager | Current server count=1 | 2021-07-13 07:49:03.101 HD Server | Thread:14020 (1) | Creating socket. | 2021-07-13 07:49:03.275 HD Server | Thread:14020 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:03.275 HD Server | Thread:14020 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:03.275 HD Server | Setting DTC encoding to Binary VLS | Thread:14020 | 2021-07-13 07:49:03.276 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:14020 | 2021-07-13 07:49:03.278 HD Server | Login has been authorized. | Username: Rollmops. | Thread:14020 | 2021-07-13 07:49:03.278 HD Server | HD Request #8 | Socket: 1 | Symbol: GCQ21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:53 | ClientReqID: 8 | Username: Rollmops. | Thread:14020 | 2021-07-13 07:49:03.280 HD Server | HD Request | Socket: 1 | Symbol: GCQ21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 25271 | ClientReqID: 8 | Username: Rollmops. | Thread:14020 | 2021-07-13 07:49:03.514 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:03.525 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:03.526 HD Server | Thread:14020 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:03.553 HD Server | Thread:10204 (2) | Creating socket. | 2021-07-13 07:49:03.563 HD Server | Thread:14020 (1) | CloseSocket call. | 2021-07-13 07:49:03.563 HD Server | Thread:10204 (2) | New receive buffer size: 262144 | 2021-07-13 07:49:03.563 HD Server | Thread:14020 (0) | CloseSocket call. | 2021-07-13 07:49:03.563 HD Server | Setting DTC encoding to Binary VLS | Thread:10204 | 2021-07-13 07:49:03.563 HD Server | Thread:10204 (2) | Allocated send buffers: 31 of 4096 bytes. | 2021-07-13 07:49:03.564 HD Server | Thread:14020 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:03.564 HD Server | Thread:14020 (1) | Closed. | 2021-07-13 07:49:03.564 HD Server | Thread:14020 (0) | CloseSocket call. | 2021-07-13 07:49:03.565 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:10204 | 2021-07-13 07:49:03.567 HD Server | Login has been authorized. | Username: Rollmops. | Thread:10204 | 2021-07-13 07:49:03.567 HD Server | HD Request #9 | Socket: 2 | Symbol: GCQ21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:38:53 | ClientReqID: 9 | Username: Rollmops. | Thread:10204 | 2021-07-13 07:49:03.569 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:14020 | 2021-07-13 07:49:03.639 HD Server Manager | Current server count=1 | 2021-07-13 07:49:03.639 HD Server | HD Request | Socket: 2 | Symbol: GCQ21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 25271 | ClientReqID: 9 | Username: Rollmops. | Thread:10204 | 2021-07-13 07:49:03.683 HD Server | Thread:10204 (2) | Socket gracefully closed by remote side. | 2021-07-13 07:49:03.742 HD Server | Thread:10204 (2) | CloseSocket call. | 2021-07-13 07:49:03.742 HD Server | Thread:10204 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:03.742 HD Server | Thread:10204 (2) | Closed. | 2021-07-13 07:49:03.742 HD Server | Thread:10204 (0) | CloseSocket call. | 2021-07-13 07:49:03.742 HD Server | Thread:10204 (0) | CloseSocket call. | 2021-07-13 07:49:03.742 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:10204 | 2021-07-13 07:49:03.851 HD Server Manager | Current server count=0 | 2021-07-13 07:49:03.852 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:03.854 HD Server Manager | Started new historical data server. Count=1 | 2021-07-13 07:49:03.855 HD Server | Thread:19992 (1) | Creating socket. | 2021-07-13 07:49:03.867 HD Server | Thread:19992 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:03.867 HD Server | Thread:19992 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:03.867 HD Server | Setting DTC encoding to Binary VLS | Thread:19992 | 2021-07-13 07:49:03.867 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:19992 | 2021-07-13 07:49:03.868 HD Server | Login has been authorized. | Username: Rollmops. | Thread:19992 | 2021-07-13 07:49:03.868 HD Server | HD Request #9 | Socket: 1 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:39:00 | ClientReqID: 9 | Username: Rollmops. | Thread:19992 | 2021-07-13 07:49:03.870 HD Server | HD Request | Socket: 1 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 151733 | ClientReqID: 9 | Username: Rollmops. | Thread:19992 | 2021-07-13 07:49:04.221 HD Server | Thread:19992 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:04.386 HD Server | Thread:19992 (1) | CloseSocket call. | 2021-07-13 07:49:04.386 HD Server | Thread:19992 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:04.386 HD Server | Thread:19992 (1) | Closed. | 2021-07-13 07:49:04.386 HD Server | Thread:19992 (0) | CloseSocket call. | 2021-07-13 07:49:04.386 HD Server | Thread:19992 (0) | CloseSocket call. | 2021-07-13 07:49:04.386 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:04.398 HD Server Manager | Started new historical data server. Count=2 | 2021-07-13 07:49:04.399 HD Server | Thread:2408 (1) | Creating socket. | 2021-07-13 07:49:04.437 HD Server | Thread:2408 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:04.437 HD Server | Thread:2408 (1) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:04.437 HD Server | Setting DTC encoding to Binary VLS | Thread:2408 | 2021-07-13 07:49:04.437 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:2408 | 2021-07-13 07:49:04.438 HD Server | Login has been authorized. | Username: Rollmops. | Thread:2408 | 2021-07-13 07:49:04.438 HD Server | HD Request #10 | Socket: 1 | Symbol: CLQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 16:37:28 | ClientReqID: 10 | Username: Rollmops. | Thread:2408 | 2021-07-13 07:49:04.439 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-07-13 07:49:04.534 HD Server Manager | Started new historical data server. Count=3 | 2021-07-13 07:49:04.535 HD Server | Thread:320 (2) | Creating socket. | 2021-07-13 07:49:04.552 HD Server | Thread:320 (2) | New receive buffer size: 262144 | 2021-07-13 07:49:04.552 HD Server | Thread:320 (2) | Allocated send buffers: 32 of 4096 bytes. | 2021-07-13 07:49:04.552 HD Server | Setting DTC encoding to Binary VLS | Thread:320 | 2021-07-13 07:49:04.552 HD Server | Received login. Requesting authorization. | Username: Rollmops. | Thread:320 | 2021-07-13 07:49:04.554 HD Server | Login has been authorized. | Username: Rollmops. | Thread:320 | 2021-07-13 07:49:04.554 HD Server | HD Request #10 | Socket: 2 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2021-07-12 17:39:00 | ClientReqID: 10 | Username: Rollmops. | Thread:320 | 2021-07-13 07:49:04.556 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:19992 | 2021-07-13 07:49:04.602 HD Server Manager | Current server count=2 | 2021-07-13 07:49:04.602 HD Server | HD Request | Socket: 1 | Symbol: CLQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 46290 | ClientReqID: 10 | Username: Rollmops. | Thread:2408 | 2021-07-13 07:49:04.645 HD Server | Thread:2408 (1) | Socket gracefully closed by remote side. | 2021-07-13 07:49:04.679 HD Server | Thread:2408 (1) | CloseSocket call. | 2021-07-13 07:49:04.679 HD Server | Thread:2408 (0) | CloseSocket call. | 2021-07-13 07:49:04.679 HD Server | Thread:2408 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:04.679 HD Server | Thread:2408 (1) | Closed. | 2021-07-13 07:49:04.679 HD Server | Thread:2408 (0) | CloseSocket call. | 2021-07-13 07:49:04.679 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:2408 | 2021-07-13 07:49:04.894 HD Server Manager | Current server count=1 | 2021-07-13 07:49:04.894 HD Server | HD Request | Socket: 2 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 151733 | ClientReqID: 10 | Username: Rollmops. | Thread:320 | 2021-07-13 07:49:05.107 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-07-13 07:49:05.144 DTC client #1. 127.0.0.1 (1) | Creating socket. | 2021-07-13 07:49:05.149 DTC client #1. 127.0.0.1 (1) | New receive buffer size: 262144 | 2021-07-13 07:49:05.149 DTC client #1. 127.0.0.1 (1) | Allocated send buffers: 32 of 131072 bytes. | 2021-07-13 07:49:05.152 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-07-13 07:49:05.192 HD Server | Thread:320 (2) | Socket gracefully closed by remote side. | 2021-07-13 07:49:05.247 HD Server | Thread:320 (2) | CloseSocket call. | 2021-07-13 07:49:05.248 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-07-13 07:49:05.248 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-07-13 07:49:05.248 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Rollmops. Result text: Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices | 2021-07-13 07:49:05.248 HD Server | Thread:320 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-13 07:49:05.248 HD Server | Thread:320 (2) | Closed. | 2021-07-13 07:49:05.248 HD Server | Thread:320 (0) | CloseSocket call. | 2021-07-13 07:49:05.248 HD Server | Thread:320 (0) | CloseSocket call. | 2021-07-13 07:49:05.248 HD Server | Server thread ending. Closing socket. | Username: Rollmops. | Thread:320 | 2021-07-13 07:49:05.351 HD Server Manager | Current server count=0 | 2021-07-13 07:49:05.351 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-07-13 07:49:06.590 DTC client #2. 127.0.0.1 (2) | Creating socket. | 2021-07-13 07:49:06.602 DTC client #2. 127.0.0.1 (2) | New receive buffer size: 262144 | 2021-07-13 07:49:06.602 DTC client #2. 127.0.0.1 (2) | Allocated send buffers: 32 of 131072 bytes. | 2021-07-13 07:49:06.605 DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-07-13 07:49:06.969 DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-07-13 07:49:07.040 DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-07-13 07:49:07.040 DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: Rollmops. Result text: Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices | 2021-07-13 07:49:07.041 Opened cached Intraday file: C:\SierraChart\Data\6BU21-CME.scid. Thread ID: 4424 | 2021-07-13 07:49:11.606 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol CLQ21-NYMEX | 2021-07-13 07:49:12.147 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-07-13 07:49:12.147 SC DTC Delayed Exchange Data | Market Depth data has been rejected for symbol: CLQ21-NYMEX. Market depth request for symbol CLQ21 for service code nymex failed due to the given SymbolID not matching the existing ID for the symbol. | 2021-07-13 07:49:12.357 Opened cached Intraday file: C:\SierraChart\Data\ESU21-CME.scid. Thread ID: 4424 | 2021-07-13 07:49:13.912 |
[2021-07-13 14:50:46] |
John - SC Support - Posts: 30973 |
We see the following in your log: Symbol Error - CLQ21-NYMEX is unknown, unavailable, or improperly formatted. Already subscribed to symbol. New subscription rejected.
This implies that there is another symbol using a different format for the same instrument, which is causing the issue. In the Main Instance first, select Edit >> Translate Symbols to Current Service. This will update all symbols to the correct current format. Then go into each sub-instance you are running and do the same thing (Edit >> Translate Symbols to Current Service). Let us know if you have an issue after you do this in all the instances of Sierra Chart that you run. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-14 08:54:18] |
Sierra_Chart Engineering - Posts: 14014 |
Also update Sierra Chart to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
