Date/Time: Thu, 25 Apr 2024 02:05:45 +0000
Shortcut for Switching Chart settings (Renko)??
View Count: 597
[2021-07-09 18:43:53] |
User275839 - Posts: 57 |
Hi - Is there some way -- similar to Study Collections -- to easily manage and switch between chart settings? Specifically, I'd like to switch quickly between different flex renko values without having to open the Chart Settings dialog and manually entering the different values. Ideally, I'd like to tie chart settings to the chart symbol (ES, NQ, etc.) and have the renko parameters change based on symbol, but I'd be happy with being able to quickly pop in different settings via a control bar item for example. Maybe there's a way to do this but I just haven't discovered it yet? Thanks for any pointers. :) |
[2021-07-09 18:46:58] |
John - SC Support - Posts: 31098 |
Refer to the following for what is available: Changing Chart Bars Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-26 14:24:16] |
BlueVein - Posts: 34 |
Are there any future plans to allow a study to do this? I.e. based on indicator values change the volume per bar parameter-- adjusting the volume per bar based on current volume conditions as to what is "normal".
[2022-11-26 15:26:25] |
Sierra_Chart Engineering - Posts: 14076 |
Yes an ACSIL study can do this with this function: sc.SetBarPeriodParameters() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
