Date/Time: Fri, 19 Apr 2024 20:40:33 +0000
[Locked] - July 1, 2021: EUREX Realtime Data from Denali Exchange Data Feed Policy
View Count: 6687
[2021-06-25 09:22:56] |
Sierra_Chart Engineering - Posts: 14014 |
IMPORTANT NOTICE: Effective July 1, 2021, the new highest quality EUREX EOBI real-time and historical data which is part of the Denali Exchange Data Feed is recommended to be used for Sierra Chart users requiring real-time EUREX data in Sierra Chart. This is the very best EUREX data feed which is not offered anywhere else. It provides tick by tick data, delivering all the trades from the EUREX, full market depth, (approximately 200+ levels), and market by order data. It will be a requirement as of July 1 to be using the following Service Packages to continue to access real-time EUREX data in Sierra Chart whether from the Denali Exchange Data Feed or other sources: -10 (equivalent to Service Package 3 with the Denali data feed) -11 (equivalent to Service Package 5 with the Denali data feed) -12 (equivalent to Service Package 5, with the Denali data feed and market by order data support) If you are using Sierra Chart Service Package 10, 11 or 12, there is not a requirement to use the EUREX data as part of the Denali Exchange Data Feed. To change your Sierra Chart Service Package, see the instructions at the end of this post. You can still use the externally provided EUREX data from other sources. However, we do recommend the Denali EUREX data. We may make this a requirement at some point for all Service Packages, but not at this time. For all users requiring EUREX real-time or delayed data, it is necessary to be running a current version of Sierra Chart. Update instructions: Software Download: Fast Update To use this new EUREX real-time data feed, refer to the Denali Exchange Data Feed EUREX setup instructions: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX If you are paying for EUREX data through your broker you will want to *cancel* that data from them, before July 1, 2021 if you will be using this EUREX data feed through the Denali Exchange Data Feed. For more information, refer to: New Upcoming EUREX Full Order Book Data Feed (Now Available!) | Post: 251401 ---- In addition to this, the Denali Exchange Data Feed provides real-time data, delayed streaming data, market by order data, market depth data, historical Intraday data and historical Daily data for the following exchanges: CME CBOT NYMEX COMEX CFE In approximately a month we will also be offering a new NASDAQ data feed as well. ---- To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-18 15:48:26
[2021-06-27 09:23:40] |
If you are considered a professional by the EUREX, and you have to pay the exchange fee through your broker also, then contact us. Or if there is no way to avoid paying the EUREX exchange fee through your broker as well, let us know and provide details. When it comes to market data feeds, and Sierra Chart, if there were not exchange fees, then we would require our own data feed to be used for the exchanges that are provided by the Denali Exchange Data Feed. The main issue, is having to pay an exchange fee twice in certain circumstances. So what we are going to do in the case of EUREX, is if you are on the Service Package 10 or higher, then it will not be necessary to activate the EUREX exchange fee access to still be able to access real-time EUREX data, from an external source other than the Denali Exchange Data Feed. The first post in this thread has been updated to indicate this. We really do want users to be using the Sierra Chart provided EUREX data feed because it is the very best and gives the best impression when using Sierra Chart, and is much easier for us to support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-02 06:40:18
[2021-08-03 17:39:27] |
We want to share this question from a user and our answer regarding EUREX real-time data: problem with service package and miscellaneous todo to secure data for DAX It clears up a misunderstanding that they had. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-03 17:47:30
