Date/Time: Wed, 13 May 2026 10:59:14 +0000
Replaying charts
View Count: 1357
| [2014-03-16 12:23:00] |
| User72822 - Posts: 16 |
It happens often that when I do a chart replay the replay stops at the end of that day..... there are more days after that specific day. I would like to go further with the next days...... In the past it happens frequently that the chart replay continues automatically for the next days if they were available. Why doesn't it work now any longer??? Can you help me with this issue? |
| [2014-03-17 00:20:34] |
| Zosimus - Posts: 345 |
Try checking "Skip Empty Periods" on the Replay window.
| [2014-03-17 00:25:54] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#SkippingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
