Date/Time: Wed, 24 Apr 2024 10:28:05 +0000
IQ FEED DROPPING
View Count: 968
[2014-03-14 13:46:20] |
User15451 - Posts: 27 |
Dear Support, This has been going on for a while and has recently worsened. After testing this on more than 4 different Internet connections and two different PC's It is apparent that IQFeed is disconnecting quite often during the day. Obviously this is very concerning. Please Help Thank You for your support |
[2014-03-14 16:29:11] |
We have not heard this from other users or observed that ourselves. We recommend contacting DTN about this . They should have some procedure in place to determine the cause of this. We do testing with IQ Feed probably about once or twice a week and have not observed any obvious connection problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
