Date/Time: Thu, 28 Mar 2024 19:32:10 +0000
Change region divider line color and thickness?
View Count: 1491
[2014-03-12 19:29:48] |
OneMoreTick - Posts: 79 |
Is it possible to change region divider line color and thickness?
[2014-03-15 01:50:28] |
vegasfoster - Posts: 444 |
99% sure you can't.
[2014-03-15 02:51:02] |
No. This is not supported. It is the same as the horizontal and vertical lines you see beside the time and price scales.
