Date/Time: Thu, 28 Mar 2024 20:20:23 +0000
ES-$INX Stopped Updating
View Count: 561
[2021-04-05 18:52:18] |
maxpi - Posts: 175 |
I was charting ES-$INX this morning when it stopped updating about 9:11am. Subsequently it seems to have updated to about 10am but stopped again. The symbol is available under File-Find Symbol but I see that it's not listed specifically in the docs for Market Statistics, not sure if that has any bearing on it. Both it's components updated all day.
[2021-04-05 20:02:13] |
John - SC Support - Posts: 30444 |
That symbol is a Premium which is composed of the two components. In order to get it to work you would need to have the Real-Time data for both items active. Therefore, you would need the Denali Exchange Data Feed for the ES and the Sierra Chart Exchange Data Feed for the $INX. You can attain a similar solution using the Custom Calculated Symbols and using the delayed data for the ES and the CFD symbol SPX500. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-06 01:42:32] |
That symbol is a Premium which is composed of the two components. In order to get it to work you would need to have the Real-Time data for both items active. Therefore, you would need the Denali Exchange Data Feed for the ES and the Sierra Chart Exchange Data Feed for the $INX. This will not work. This will not work properly either: You can attain a similar solution using the Custom Calculated Symbols and using the delayed data for the ES and the CFD symbol SPX500.
The stock index premium symbols are considered out of date and you need to used the new method described here: Custom Calculated Symbols: Stock Index Futures Premiums Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-06 01:43:45
